60mm too big?
I’m sure that the Renn takes a standard length valve stem, a 60 is too long, and I’m pretty I think that the H3 is the same.
60mm is too big for the Renn
Borderline for the HED3. I’ve used a long one but I’m thinking it is a 45 or something like that. (Continential tube)
I use a short valve in both.
jaretj
I used the standard length stems. With a Topeak SmartHead pump you don’t need a crack pipe adapter for either wheel (at least on ours).
I use a 45 on my HED. disc
I race that exact set up and run the standard 36mm valve, you can still use one of those microflate CO2 inflators if you flat as well.
~kweel~
Ditto here.
