What is diameter of Syntace C3 aerobar extension?
I’d like to use something similar to baryfly tt mount to the outside of Syntace C3 aerobar so it doesn’t interfefer with BTA setup for my Garmin Edge on training rides. currently using the Garmin o ring mount. Stem top cap or handlebar mounts wont work for my situation.
I’ve tried a couple but they are for 22.MM bars. Anyone know what the diameter is &/or what tt type of mount would work?
Thanks,
Barb L
I’ve measured three of them and they all seem to be in the 23.6 mm range. I use a Zipp TT Quickview Computer Mount (which is specifically made for the newer standard aero bar diameter of 22.3 mm) on Profile aero bars. I tried it out on a Syntace without the rubber insert and it fit fine. One turn of black electrical tape would make an adequate mounting surface. Barfly also makes a "4 TT aerobar mount " that they say fits 22.3 or 24 mm bars.
