What headset size fits a specialized transition?
I need to fix a specialized transition frame. This is a total build up from the bottom on up. All I have are some brake levers and a seatpost.
1" cartridge integrated headset bearings i believe.
It’s a 1" steertube. Sealed cartridge bearings top & bottom.
From the specialized website: Use 36° x 45° x 38mm (1”) cartridge bearings
Thanks, all!
Is there any chance someone can show me via link? Like maybe one from Ritchey or FSA?
Pretty please?
feris?
You wouldn’t order it from them; you’d just order it from a specialized dealer. All you need are the bearings. Or, that’s all you should need. It’s not a stock FSA/Ritchey part.
Totally lost with all the jargon here. Spesh no longer supporting that frame.
Any luck finding these online anywhere or do I need to go to a dealer? I need to replace mine pretty badly.
A year ago I needed to do the same and the local Specialized dealer had the bearings on the shelf.
