Limus is really slow in anything but heavy mud because it doesn’t have the continuous center tread block like the Rhino style (IE:PDX) tread types. PDX would be a much more versatile tire, and if you’re going to have just one tire, that’s about as good as it gets.
PDX in tubular doesn’t run wide like the clincher version.
I’ve run through at least a couple of sets of Rhinos, Super Muds, PDXs, and Limus, and…
- Rhino and PDX are pretty darn similar. Roll as fast as a Grifo in a straight line, both lose traction in cornering on hard surfaces. PDX isn’t as supple as the Rhino, but it makes up for this by not rotting to pieces if you point a hose near it.
- Super mud is almost as fast as the above in a straight line, and holds edge better on harder surfaces, but packs up with mud much faster. FMB pre-treats casings so they don’t rot nearly as easily as Dugast.
- Limus is the slowest of the mud tires in anything but mud, and packs up quickly when conditions are sticky. Team edition casing is pretty darn close to FMB (and the first ones I had actually *were *made by FMB). If it’s really slow, and the mud is really sloppy, these tires will get grip when nothing else can, and this is when you’ll actually see a couple of the Euro guys switch to them, otherwise they’re on Rhinos.
Reason to run something like a Grifo or the Clement MXP isn’t that they’re faster rolling than the Rhino style (continuous center block takes care of that) it’s that their tread blocks aren’t as tall, so they don’t fold/squirm under cornering forces on harder surfaces. They also don’t pack up when the mud is sticky or mixed with grass which can be a real issue with the Limus in particular.
The white compound tires actually add a little bit of squirm back in to the equation because they’re softer. They also don’t wear nearly as well as the carbon black compounds, but they may function better on ice and in below freezing type conditions. I ran silica based tires on the Bend courses the ice bowl year, and even if it was psychological, was glad I had them. Wouldn’t run them as an every day tire. Have seen tread blocks blow out of white compound FMB tires on the first ride.
If your Limus tires are a couple of seasons old, you’re probably already running the baby Limus. It’s really just the limus pattern with lower center blocks. Ride a Limus on the trainer for a few hours and you’re pretty much on one.
If you’re going to have two sets of wheels, it’s still just really hard to go wrong with a Grifo pattern tire and a Rhino pattern tire. When 100% of the euro-based pros are choosing the same 2 basic patterns, it’s probably a good call.
Personally, after yet another early summer day of inspecting my wheels and finding that I lost a couple of tires to rot over the off-season, I’m probably going to run Clement MXP & PDX and the new TUFO cubus variation as an intermediate. Just don’t want to deal with cotton casings anymore, and they’re really so close in performance now that it’s not worth doing so.
M
Ramblings about CX, and the CXWOTD
