I went for an easy, aerobic-paced run today and the heart rate monitor was off the charts - up to 192 BPM without even breathing hard. I chalk it up to problems with the HRM.
Thinking about it later though, I started to wonder about a couple of things: does a heart murmur (I’ve had one all my life) throw off a HRM reading? Looking at another possible cause, will an iPod throw off an HRM reading (I happened to be running with one)?
my timex sometimes gives erratic readings when the battery starts to run down, that and when I run past the hospital here which has the local wireless ISP transmitter on the roof.
I usually run with either an iPod mini or a shuffle, and either a garmin or a Polar HRM and have never noticed any interaction between music player and HRM.
Did you moisten your chest and the strap? I always get strange readings with my polar when I don’t actively moisten my chest and the monitor before starting a run or if it is dry and windy. Just another thought.
I’ll bet you 5 to 1 that either the battery in your HRM receiver of HRM transmitter/chest strap is low and requires replacement. This will cure your problem immediately.
