Looking to weight weenie my mountain bike and among the upgrades and component swaps I’m considering is titanium bolts. Specifically I’m thinking of titanium bolts for the disc brake rotors and the bolt holding the disc brakes to the post mounts. Is this a safe application for Ti bolts? I’m also contemplating Ti bolts for the seat clamp (I’m only seated when pedaling on smooth surfaces anyways) and the cockpit bolts (shifter, brake levers, but not stem bolts). Any risk of using Titanium in these locations? Also what does everyone think about some of the lighter-weight through axles?
I use ti bolts for my brake rotors, in part to avoid corrosion issues.
I’m not sure I’d be comfortable with the ti seatpost clamp. I think my SRAM drivetrain and brake bits are already using ti bolts.
What options are you looking at for lightweight thruaxles?
Yes it’s safe as long as you don’t change your saddle height often. Careful witht he hex ehad.
Extralite or Carbon-Ti thru-axles (or any part) will make you save sensible weight. NOt cheap though.
https://www.extralite.com/mountain-bike.php
http://www.carbon-ti.com/products
LOuis ![]()
Functional weight weenie projects are always fun! The Robert Axle Project thru axles are very nice quality.
// titanium screws work fine when the load is straight at right angles to the screw head, they do not tolerate bending or uneven screw head seating like steel …
Been running a similar project on my Scott Spark. You are safe with titanium bolts anywhere on a mountain bike IMHO. But before going that route, there is a better bang for the buck in terms of weight savings before you drop 100$ to gain 20 grams. A good place to start is checking R2 Bikes in Germany https://r2-bike.com/. They weigh almost everything they sell, and you can list items by weight. I have already taken the bike from 12.45 kilos to 11 including a telescopic seat post that adds like 400 grams. And that without spending too much. Some examples below:
Wheels: ZTR Crest rims are at the lightest end, with reasonable strength and a pretty decent price. I am running them with DT 350 hubs (no point in going 240 in my opinion)
Tires: running a Continental Race King saves me 400 grams over my current tiresCassette: Garbaruk makes very good light weight cassettes at a fraction of Shimano or Sram prices. You can even go 12 speed on standard shimano hubs, only it will be 11-52 instead of 10-50.
Pedal spindles: using titanium spindles can save you around 40 gramsDisks: Ashima Ai2 are at the lightest end for very little money. I also found that at 74kg I can run 160 at the from which saves weight not only at the disk, but also lets you get rid of the spacer and use shorter bolts. This would be the time to add titanium bolts to the disk and the calipers.
Hope this helps with your project.You might want to check this crazy project taking light to the extreme:https://www.pinkbike.com/news/building-the-worlds-lightest-29ers.html
Go to your lbs and inquire about drillium.
Edit: my bad, don’t ask your LBS, ask Amazon:
Shit, what can’t you get on Amazon?
What kind of bike setup are we talking?
In general its most efficient to cut weight on the biggest things and expensive to save weight on the small things
Depending on your gear you might be able to save way more grams looking at helmet, shoes, shirt, pants, pump etc, getting a compact spare, and weight weenie bike tool
