This being said after I finished gluing an extremely light 19 mm Vittoria Pista EVO CL tire to a Zipp 1080. The wheel (sans tubular) was almost perfectly balanced but the 110 mm extender threw it out of balance.
I have balanced some discs and spoked wheels putting the magnet in the right place, but I am not sure if it is worth it.
Then I just feel better thinking that the wheel is balanced ;-).
Consider the speed a car tire revolves at 90 mph vs how fast a bike tire revolves at 20 mph. Essentially, the car wheels are gonna be a little smaller, and move much, much faster.
It is fairly common for a wheel to be balanced in my area. My LBS counterbalanced a 404 with a small weight added to the rim a while ago, but it’s simple enough to do yourself. At high speed the vibration every wheel revolution can be quite noticeable. Whether or not it’s worth balancing is another story, but as an engineer it’s hard to ignore!
My brother in law asked me the same thing. I said that it makes no difference in a bike wheel because there are only two. As long as they are true I dont really think it matters. Unless you are going to put a slide weight on that felps rotate the wheel forword. Never know could save you a watt or two
English is my first language and I still screw it up !
It was included in the charge when getting a wheel trued + spoke replaced. I certainly noticed the vibration on an early model 404 with an 80mm stem tube so I don’t think it’s as silly as some of you guys make it out to be.
Sorry if I implied it was silly. Okay I am not sorry. But I do remember reading about a slide weight to put on the spokes to get wheel momentum going faster. Anyone else remember the product I cannot recall it. I will do a google see if I can find it.
I try to balance my wheels with the computer magnet, and Zipp has a bit on their website about balancing wheels. I swear that i can feel the out of balance on my 303’s because I had to resort to bontrager extenders which are made of steel and weigh about 7grams more than the tufo ones I was using. That wheel and tire are so light it is enough to feel the weight over about 25mph.
I think that the real answer though is that the difference is not significant enough to effect anything.
If you’ve ever gone fast down hill with a wheel thats badly out of balance it can be annoying. On a nearby hill its common to see 70-80km/hr if you really push it, and with this particular wheel it was very noticeable… so I don’t see how it’s such a silly idea.
