Previously Ironman 70.3 Santa Rosa bike course - 2:32:30. Power @ 221w.
Wildflower - 2:47:10 @ 241w (I blew up on the run, but it’s a DAMN tough course & heat).
My FTP is now 300. It is recommended that your 70.3 power is 75% of your FTP, so that puts me at 225w. But I feel that I can easily push more than 225w and still run really well off the bike.
Conventional wisdom says depending on how well trained you are you could go to 80% FTP, maybe slightly higher. But keep in mind that should be normalized power, not average power. Sounds like you found your limit so let that guide you.
75% on a 70.3 seems really low. I race full distance at 78-79% and 70.3 at like 87-88%. I run 1.25 to 1.28 for my 70.3 with a half marathon PB of 1:23:30. I think my FTP is at about 305W.
I thought a good recommendation was to do 180TSS for 70.3 and 280TSS for full distance.
Your PBs are quick.
Your %s won’t apply to slower athletes.
What are your thoughts?
i think if you rode a 2:32 off 221w you should look at your fit. (how much do you weigh?)
I’m usually right around 82% for NP in order to have a run I’m happy with. I’ve found that even a few percentage higher can lead to a much slower run time. The flatter the course, the closer AP will be to that 82%. At Quassy a couple of weeks ago I was at 263 AP and 281 NP. On a flatter course AP will be in the mid 270’s.
Just a general question- how do you all monitor/track your NP during the race? On a hilly course I imagine this can be difficult. Do you have AP or NP as one of the data screens on your garmin (or other bike computer of choice)?
I display both AP and NP on the Garmin 520 during a race.
.75 IF is most likely too conservative. Here is a chart designed by Dr. Skiba that you may find helpful
This is a great chart. For “Average” is this NP or AP? What is meant by “power ceiling” – is this the highest power you’d want to push for any sustained period of time (e.g., a 5 min climb), or the max you’d want your power to hit, period (i.e., 15 sec push up a hill)? It’s a pretty tight window…
That chart is referring to AP for each event distance based on Skiba’s analysis of files from pro’s and Agers in his book, “Triathletes Guide to Training w/Power”.
A power ceiling is essentially where you want to cap your power for 2-3 minutes during the ride. You can determine your own power ceiling by doing a race simulation. but a For a 70.3 race sim, I would do a hard 40 mile ride @ target power and an 8 mile run @ target pace. If you can’t run even splits and you’re fueling is dialed, you rode too hard and should adjust.
But, dont take it as the gospel, this chart is just a really nice starting point.
That chart is total bs. Because, an amateur should hold 100% ftp on an Olympic? For a fast rider the Olympic bike leg is let’s say an hour (pretty sure a lot of people on here don’t break the 25 mile in an hour).
Ftp is max effort for an hour.
BUT you still need to run a 10K after max bike performance? AND you just swam a bit before?
If I had looked in the correct row however I would’ve seen that that describes power ceiling, not average
