I wrote: I think to make full use of Rotor Cranks, you have to do two things…change your timing to take advantage of the potential to lessen the so-called “dead-spot”,…
Gary asked:
>> Is this speculation on your part? I have not had this experience in my 10,000 miles on my Rotors, nor have I ever heard this before, perhaps you can explain this more.
Yep, pure speculation on my part. I don’t feel a change in timing, but, it makes sense that the muscles must fire with just a little different timing for maximum benefit, because the pedals no longer have the “normal” relationship to one another, i.e., the top pedal is over the top before the bottom pedal is at the very bottom. Again, I don’t FEEL this, just speculate that a slight timing change may be “learned”, and it may be learned very quickly, or it may take a while for some people…I don’t know.
Another way to put it is: in order to **not **have a “dead spot” at the top of the pedal stroke, the rider must be providing power to the top pedal before power stops being provided from the bottom pedal, right? (Assuming a circular pedal stroke, ala PC-style, isn’t being performed.) If, with Rotorcranks, the top foot is over the top more quickly compared to normal cranks, the rider CAN push with the top foot a little earlier compared to normal cranks. The key word is CAN. Just because Rotors make that more easily possible, doesn’t mean that it is being performed…that sounds like different timing to me.
I’m sure there will be people that say, “OK, I begin pushing over the top soon enough with regular cranks so that I don’t have a true “dead spot” in the first place, so Rotors aren’t eliminating something that I don’t have.” I’d say, this kind of pedalling is probably possible, but, if you learn to time your push-down just a tad bit sooner like Rotors enable you to do, the Rotors will help you get into a more powerful pushing-down position just a little sooner than you could with normal cranks.
However, a change in timing may not be required. In which case, the benefits of Rotors may be more from taking advantage of the increased “dwell time” of the extensors in the power phase of the downstroke, and not the elimination of the “dead spot”.
Again, just speculation on my part.
Whatever the reason(s), I’m now faster (since I had my recent hill-climb break-through) on Rotors than anything else on real-world courses…especially the flats…it’s like having one higher gear on the rear cog at the same perceived effort.
Oh, and to stay on topic, PC’s are wonderful for training to run better…at the very least! (I think they do more than help my run, though, I think they help my biking, too.)
