Joe, I train and race on Rotors, but, I also train on PC’s…25-50% of the time. I have about 1400 miles on Rotors, and am just now getting where I’m faster up steep hills on Rotors than PC’s. On long flats, I’m slower on PC’s because I simply have not recently trained on them enough to be very aero and/or adapted well enough to keep on cranking at an economical rpm for longer than 15-20 minutes at a time. Last time I checked, on a rolling course, I’m faster on PC’s than regular cranks, because a rolling course provides the short breaks my hip flexors need to recover.
If my hip flexors tire when on PC’s, I’m going to slow down, so having a fixed crank system of any sort is an obvious bail-out benefit in a race. I’m faster on Rotors on the flats compared to anything else I’ve ridden, I actually use a 54X11 on Rotors; yesterday I did a long ride where I had no wind and was able to ease along for extended periods of time (upper 70’s-low 80’s rpms) in the upper 20 mph range at a heart rate below 125…I don’t do that on any other crankset. I think to make full use of Rotor Cranks, you have to do two things…change your timing to take advantage of the potential to lessen the so-called “dead-spot”, and train your extensors to benefit from the increased “dwell time”: a phrase I just made up to describe the slight slowing of the downward moving leg (coinciding with a speeding-up of the upward moving leg). If the extensors are the best muscles for moving the cranks around and around, take advantage of this benefit as by extending the time the extensors are working during each pedal stroke.
Although it takes some time and work, it was apparent from the very first ride that Rotors had immediate benefits. But, they aren’t a majic bullet…notice it takes time and work.
It has taken me over 1000 miles to get faster up steep hills (8-12 mph at near maximum HR) on Rotors compared to PowerCranks. I think this is because PowerCranks absolutely prevent any backpressure on the rising crank. Pushing so hard at relatively low rpms (60-70) while eliminating backpressure must be difficult for me to do, so I was faster on PowerCranks. I think the reason I’m finally faster on Rotorcranks than PowerCranks up these monster hills is due partly to my continued PowerCrank training (I’ve gotten better at eliminating any backpressure on the cranks when on non-PC bikes), and partly due to the work done on Rotors in order to benefit from the characteristics of the Rotorcranks.
To make a crankset that could combine benefits of both sets of cranks, I would envision a PowerCrank-type clutch on an eccentric bearing, or, a sliding crankarm system that would effectively lengthen the crankarm on the downstroke and shorten it on the upstroke. This way, zero backpressure on the upward moving pedal would be enforced by the clutch, combined with more dwell time on the downstroke (like Rotors) or a longer effective crankarm on the downstroke with faster-moving shorter effective crankarm on the upstroke (with the sliding mechanism). Could it be built? Sure. How much would it weigh and cost? I have no idea. I guess you could make a sliding crankset like this without the clutch, but you wouldn’t have the deadspot-reduction possibility that and eccentric system might provide, so the eccentric might be the better way to go.
I’ll always train some on PowerCranks for their run benefits, as well as to minimize/eliminate what I perceive be a flaw in my pedal stroke (I know there are those that don’t think backpressure on the rising pedal is a flaw, or that you can sufficiently “learn” to eliminate the backpressure just by working on your pedal stroke…fine. You may be right. I happen to think I do better with a PC-style stroke, and I’ve found no better way to engrain the PC-style stroke than to ride on PC’s). However, racing on Rotor Cranks doesn’t prevent me from performing a PC-type stroke (although I don’t have the immediate feedback like you do with PC’s), and it allows me to keep pedalling if my flexors tire. Plus, I think Rotors offer timing and biomechanical advantages matched by no other crankset I’ve ridden.
I like 'em both. I think the (alleged) benefits of each crankset system are real, and additive. I think it’s possible to combine the two crankset characteristics, but, at what cost and what level of reliabilty? And, you’d still do well to have a lockout in case you lost a hip flexor during a race.
