http://www.chucksbikes.com/store/indexcr036.htm
Buy this crank.
Remove the spider
Get some modeling foam, but only the stuff that is dissolvable in acetone.
Wax the crank’s faces (where the bolts and BB axles are), including where the pedals and BB mount (both sides), just not the sides of the crank.
Cut your modeling foam to shape to attach to the sides of the non-drive side of the crank.
superglue the foam onto the crank sides, making certain no glue ends up on the faces of the crank.
Suss out the spider fairing, then cut to shape.
Repeat the proceedure #6 onto your drive crank.
Make a mould out of fibreglass from your foamed cranks. Make certain to spray some peel-ply onto your crank faces.
Glass the foam. Follow resin manufacturer’s directions on curing. I like using a low-tow, easily drapable fibreglass, and using many, many layers (like 10 or 20).
After final cure, remove crank, then use acetone to remove the foam from your new mould.
Clean mould thoroughly, then smooth out any imperfections with putty.
Polish, then wax mould several times.
Spray peel-ply into new mould.
Make a fibreglass “splash” of the new mould. This will show whether or not your mould is smooth. You will want to vacuum-bag this “splash”.
If mould is not perfect, then work on smoothing until perfect.
If satisfied with mould, use carbon. You will only need three layers of carbon to have a semi-structural over-wrap. You will need to vacuum bag it.
Clean flash and drill appropriate holes for access to pedal holes and BB mounts.
Sand carbon cranks with 80-grit sandpaper and clean with acetone.
Use 3M DP 460 to glue crank fairing onto crank. Make certain pedal threads and BB mount are protected from the glue.
Finish the over-wrap with epoxy, or leave the crank over-wrap unfinished.
Re-install spider.
I think I am going to try this. I will photograph and post onto forum when finished.
See, scum bag knows a thing or two about carbon.
