I currently have Vittoria Corsa Speed G+ 2.0 25mm with latex tube as race setup but I’ve also heard good things about Continental Grand Prix 5000 TT (TdF) 25mm tire. Is it worth switching? What I want is fast tires with more puncture resistance. I use GP5000 regular edition for training and road bike and I’ve never had a flat ever since I got them, so I have nothing but good experience with Continental tires. Anyway, I wanted to ask here nefore spending money. I appreciate if you guys can share experience and thought. Thanks!
I have tested both extensively from a rolling resistance perspective and they are so close, go for reasons other than CRR, ie puncture resistance, ease to put on, price…those I don’t have any data on.
Do you think the contis are more puncture resistance than the vittoria’s?
https://www.bicyclerollingresistance.com/road-bike-reviews/compare/continental-grand-prix-5000-2018-vs-michelin-power-time-trial-2020-vs-vittoria-corsa-graphene2
On tread thickness, much the same.
If you’re worried about punctures then the GP5000 TT is the better option. I’ve used these for training whereas I wouldn’t do so with a Corsa Speed. Crr wise they are very close so you’re not giving up much - another option is a Michelin Power TT which I quite like and have used in training too, but they’re not as robust as the GP5000 TT.
you are comparing the wrong conti and vittoria tyres
iam a fan of the michelin thicker thread and dont forget its tested with butyl inner tube vs 20 g sealant for the other 2 . its a wash between the three to be honest and aerocoach would seem to agree.
at least if you run latex tubes the michelin is the one and i would agree its a tinny bit more puncture resitent and more offten than not the cheapest of the three
interesting at least we agree the the vittoria is the most fragile lol
Hi Xavier - how does the Titan do with the GP5000 TT? Wrong shape compared to the corsa speed?
Vittoria Corsa Speed G+ 2.0 25mm with latex tube as race setup but . . . Continental Grand Prix 5000 TT (TdF) 25mm tire.https://www.bicyclerollingresistance.com/road-bike-reviews/compare/continental-grand-prix-5000-2018-vs-michelin-power-time-trial-2020-vs-vittoria-corsa-graphene2
On tread thickness, much the same.you are comparing the wrong conti and vittoria tyres
https://www.bicyclerollingresistance.com/...toria-corsa-speed-g2
iam a fan of the michelin . . . Thank you. I have replaced the Conti one in this comparison:https://www.bicyclerollingresistance.com/road-bike-reviews/compare/continental-grand-prix-5000-tt-tdf-vs-michelin-power-time-trial-2020-vs-vittoria-corsa-graphene2
But the Vittoria I chose is the non-TR version which I assume the OP would be rolling, since they have tubes in. You have selected the TLR version of the Corsa. Whatever, the Conti’s Crr is better than the Vittoria, on those tests but quite a bit worse in terms of its puncture resistance score.
Exactly, I feel nervous whenever I race with that tire!! And that’s why I’m thinking about switching.
I agree all these tires are pretty close. I use 25mm Corsa Speeds as my daily tires on my TT bike with latex tubes and very rarely get flats (maybe once a year). This might be a combination of decent roads and my running lower tire pressures.
One factor in my choosing Vittoria tires is that I find the Contis to be marginally harsher in ride quality. I find comfort definately translates into better race performance for me but YMMV.
I have a bunch of regular GT5000 tires, so I will train with them and race with Vittoria. You are right. They are definitely comfortable and smooth.
At the end of the day you will get many different opinions which one is the least likely to puncture
And I guess at the end of the day the least biased is the rolling resistance test but then this is not always real world .
If you are nervous then maybe non of the three is right …
Does any of the Continental aero magic still exist, or has the spell worn off?
No, it actually works very well with a 5000 TT. The shape is slightly different to the older clincher 5000s.
Anyone switching to Conti’s, I highly recommend treating yourself to one of these:
https://koolstop.com/products/kool-stop-tire-bead-jack-ks-tj
I’ve always found Vittorias, in general, to be more fragile than Contis.
Contis are more supple, more durable, with better grip, and sublime road feel.
IME: Go Conti.
https://koolstop.com/...tire-bead-jack-ks-tj
It depends on your wheels. I can put the tires on with hands with no problem. Zipp wheels and tires are GT5000.
I have one Chinese made cheap carbon wheel and oh my goodness. It’s a lot of hassle to put the same tire on.
Interesting, my personal take is the opposite. I tried (tubed) GP5000s and found the grip worse than the vittorias I’m used to. But when I went to put some vittoria rubinos tubeless onto my new Roval wheels then they were the second tightest and hardest to install tyres I’ve ever had. The worst being a dedicated wheel on trainer tyre some 20 years ago and I swear my thumbs haven’t recovered yet from that.
True, my clincher/tubeless tire experience is limited to a few wheelsets.
Zipps + Vittoria Corsa tubed clinchers = SUPER easy
HED Jets + Conti 5000 tubed clinchers = horrible
Bontrager RSL + Conti 5000 Tubeless = horrible
