This whole conversation is interesting. I am the first to have put a lot of focus on Crr for tire selection
According to Xaviers’s data the new Corsa will get a 70kg rider at 5h IM pace less than 2 watts of saving on RR
No consideration of aero (2 watt is easy to find)
No discussion of proper tire pressure (2 watts trivial to find)
No discussion of width which impacts the above 2
Then we needed to quantify flat resistance
For me, selecting the two tires based on CRR is like ordering a double big Mac, supersizing the fries but feeling good because you ordered a diet coke
Maybe there needs to be an article on optimizing the whole wheel. As a wheel supplier, maybe Xavier’s up to it
A anecdotal note here re:puncture resistance. The word is that Ineos used the GP5TT’s for the whole TdF and didn’t suffer a single flat. Based on past experience with the Vittoria Speeds, I’m not sure they’d be up to that. I know the construction method has changed a fair bit, so I may be speaking out of turn. Also UAE was using the TT almost exclusively as well.
Spent over a week testing on roads like this with the GP5K and 5kTT. Pressure from 50 to 90PSI, riders from 60 to 75kg, 25,28 and 30s. Over and over, not one flat
https://youtu.be/I3R7iNxmCZ4?si=DnvA7pHynXO7W6J6
Anything you can share from your results? My guess is that smooth roads can handle more pressure than hookless rims generally allow for. And on tough roads we’re probably running too much pressure.
Wow, you’re good !!
Here’s a summary of what we did
- tests performed in Girona
- 4 pro riders, at least 2 are doing the TDF this summer, they are all doing the Belgian races in a few weeks
- purpose was to confirm the pressure numbers they were using were correct
- we were supposed to do 3 road types. We only did 2. Pretty good (not perfect) and pretty bad. Pretty good is what I would say most IM races I have done have been. I have done about 24 IM branded events. Example Syracuse was probably the worst, Haines was not very good. China was perfect, Tremblant good. None of these roads were even close to the “bad” we tested. E3 in a few weeks may be
- riders were 60, 68, 74, 75kg
- tires were 25,28 and 30
- 2 wheel types, one with wider inner diameter
Part of this started debating pressure and pressure calculators. My argument was “if Silca calculator is right, your pressures are too low. If you are right, Silca is too high”
We ran each test at 50,60,70,80 and 90PSI
We used instrumentation to measure performance. Doing X km in Y time using Z power. All environmental conditions measured (wind for example) and logging vibration data
Optimal tire pressures were much higher than expected on “good” surfaces.
The bad surfaces, were really bad and lower pressures prevailed. Lower than expected.
Hookless wheels would not have been useable to achieve many of the optimal situations. Maybe the 60kg rider. The wheels were not hookless, although they did have a max 5 bar sticker on them that I had to ask permission to bypass. I was assured they had been tested.
We did some improvements on the instrumentation and can do a quick protocol to get optimial pressure on race day.
We asked the rider “what pressure did you think was fastest”. They always got it wrong.
Tables that say the 28mm has a lower rr than the 30 are a little misleading. You would have to compare the 28 at one pressure to the 30 at the other pressure.
I would say, “if you can’t test, go with the Silca calculator”.
It’s pretty easy to be 4w off. In some cases more.
Lots of ideas on how to make the test process/optimization even better.
The riders now hate me
