So the bike shop where I bought my bike put Vittoria Corsa’s on my HED Jet 6/9. I checked my disc today a HED Vanquish and it has a GP 5000 which is what they put on my Mavic 30mm wheels.
I bought the bike a year ago from a shop out of state. Would it be a big issue to run the two different tires? Jet 60 front with Vittoria Corsa and rear Vanquish disc with a GP 5000? I can’t believe they did it and I didn’t notice until now. It will be my first race this weekend since 2019.
You are fine if the lower RR is in the rear. The bike will only slightly compress.
However, if it is in the front, you are screwed. The difference in rolling resistance will cause your bike to split in half with the front taking off and leaving the rear behind.
I thought I’d be fine although I’ve never mixed and matched tires. The tread is very different on them, so I wasn’t totally sure if it could cause an imbalance.
Just be careful GP5000 has a lower CRR and therefore has a tendency to try and overtake the front due to the greater CRR of the Corsa and can be quite dangerous when that happens…
I use this exact combination. The shop only had one Corsa speed 2 left so I stuck that on the front and put a GP5000 on the back.
I would say you have them the wrong way around.
If the aim is speed, I’d put the GP5000 on the front where the load may be slightly less, thus less impact from higher rolling resistance, but perhaps more importantly, the GP5000 is I think more aerodynamically advantageous than the Corsa.
Also since the GP5000 is a more robust tyre, and the front is the more dangerous place to suffer a sudden puncture, there’s another reason to favour the front for the GP5000.
I can’t see any reason to put it on the back except if you think the chances of a puncture on the back are greater do to slightly higher loading, which is feasible.
But of course the potential for tyre imbalance to split the bike in half does make these all mute points!
You make a good arguement, however having managed to get a Cosra Speed TLR and a latex tube on to my front wheel it is staying there until it needs to come off! Increased wear and increased puncture risk swayed my decision at the time, however the primary issue was how difficult it had been to get the Corsa Speed! If I had the choice at the time I’d have Corsa Speeds on both wheels.
I only TT, I don’t do triathlons, and earlier this year - on the set up above - I rode a 22:05 ten mile TT, my PB is 22:04 - if I had put a Corsa Speed on the back instead of GP5000 I would have a new PB.
