Visiontech 230 mm clip-ons - where can I get some?
Hey all,
I was down south (LA - 3 stores) and could not find the smaller VT clip-ons (preferably alum.) in either 230mm or 250mm. Anybody know where I can find some in stock?
Dave
Bikesport, Inc.
(313) 278-1350.
As soon as I have my P3SL built up and I can measure everything with the syntace bars I’ll have in place - I’ll be calling. The only thing I may need to know is if there is a difference in pad placement fore/aft comparing a syntace base bar/C2 small clip ons vs the VT’s.
I want to switch from syntace as the VT’s give you a lot more options with regard to pad height - you can go much lower with the VT’s and they are faster…plus variety is the spice of life.
Does anybody modify arm pad height from race to race by just swapping out risers or does it change the arm/foream/wrist angle too much? For example - have a 12 cm drop for oly/sprints but change spacers to reduce the drop to 9-10 cm for an IM?
Dave
Make sure you get the right clamp/ bar size as VT makes both a 26.0 & 31.8
QBP has both in stock most of the time so your LBS should be able to help you out.
