Or is there an angled spacer that is compatible?
Which base bar are you referring to? If it’s this: https://shop.visiontechusa.com/en/type/aerobars/aerobars/triathlon-time-trial-track/metron-tfa the angle adjustment works the same way as using the regular extensions.
No this one.
https://shop.visiontechusa.com/en/aerobars/triathlon-time-trial/metron-tfe-pro
I realize those are the extensions you’re asking about. My question is which base bar you’re using?
I happen to have a set of the extensions you’re asking about, and I have them mounted on the aerobar setup I linked above. The mounting system for the extensions in the aerobar system accepts the Pro extensions, with all the tilt adjustments working the same way as original.
No this one.
I’m sorry, yes that is the same Metron base bar. My bike came assembled from QR and I can’t find additional spacers that may have come with it.
Did your TFE extensions include this bridge:
https://www.fsaproshop.com/products/tfe-aero-bridge
If so, then it bottom surface interfaces to the spacer stack to allow for angle adjustment.
If not then you need that bridge and the Angle Adjustment Bracket:
https://www.fsaproshop.com/products/aerobar-extension-angle-adjustment-bracket
Sadly the bracket is out of stock until mid-summer.
There’s a good diagram here: https://shop.visiontechusa.com/en/files/index/download/id/f9e743bb3e55f4b735d1598a80da924e591/
https://www.fsaproshop.com/...e-adjustment-bracket
There’s a good diagram here: https://shop.visiontechusa.com/...35d1598a80da924e591/
Yes I do have that. Thank you for the clarification!
