Or you could fly yourself, a coach, and all your gear thousands of kms to the nearest wind tunnel…
(I’m not dissing wind tunnel testing, here, btw. It is the gold standard, and permits quick equipment changes. But it’s not what you’d call more convenient or accessible to the average Joe, by any stretch. )
Or you could do neither…that’s what I’m saying. Seriously, something as minute as a visor on the helmet is not worth this much trouble (at least not to me). Fitting yourself on a brand new bike might be worth the wind tunnel time and money, but something as minute as this certainly isn’t, particularly when you consider the magnitude of the potential gains relative to the time and money expended.
If you mean by this that aero testing is not for everybody, then I will wholeheartedly agree with you. I mis-understood your direction on this. However, for those who want to know these kinds of things, there are ways to find them out.
That’s the mystery that is aerodynamics. Surprisingly, visors don’t always improve aero efficiency.
hmm…proof please?!?
Look through this Slowtwitch post and you’ll get some firsthand opinions:
http://forum.slowtwitch.com/...um.cgi?post=2566897;
You might be surprised at the accuracy of a carefully-controlled VE test on a track. Modern sensors can do wonders…
Carefully controlling everything else can’t fix a +/-5% variability in power output readings.
You can get better-than-manufacturer specs out of a power meter by doing a careful calibration. Manufacturers quote specs that they can support for the masses. This doesn’t mean you can’t carefully re-calibrate your power meter to get much better than 5%. Again, it’s a question of wanting to do it…
I doubt that any of the other things this guy is testing will have a significant enough effect that anyone could definitively say that the improvements were a result of the change in equipment and not simply variability in power readings. I’m sorry, but I just don’t think that this will even give you a good first approximation of anything but the effects of the largest changes to equipment or position. I tried searching for the results of tests conducted with the Chung method to try to find the smallest difference in drag that they could discern, but my search was fruitless. I could possibly be convinced otherwise if you send me some examples. I feel like I should have mentioned this before, but, supposing that a carefully controlled VE test is accurate enough, this doesn’t sound like it’s going to be carefully controlled enough to be accurate. Perhaps that is the rub.
Again, let’s not confuse whether the average Joe can get it to work vs., say, someone like Tom Anhalt. There are those out there that want to be Joes and others that want to be… well… er… Tom Anhalts.
Look up the Simkins Egg brake stuff. It’s extremely easy to find. Aw, heck… let me do it for you.
Here:
http://www.google.com/...iDmgryLg&cad=rja
I doubt the sensors as much as I doubt the rider. In static wind tunnel testing the rider can throw off the test with even the slightest positioning change (knees in/out, back arch, head position, etc.) This is why companies that actually care about test integrity (like cervelo) use a dummy rider. I just don’t see how a rider could maintain EXACTLY the same position for miles on end on a velodrome.
You’re totally right about this. Dummy riders cost a lot less, too.
Aero testing of any kind requires that you care about all the details. Again, for those who care, though … it is possible.
