Hi everyone, I got lucky enough to get the uberhund blitz aero bar. The only problem is that it didn’t come with the elbow/forearm rest or the pad. My question is, does anyone know any compatible rests that would fit on these aero bars?
Thanks, nick
Those are pads only. I need the plastic/carbon rest that the pad goes on
Just from the look of them, I would check on the bolt width for the Zipp Vuka pads. They look similar too me. I can measure mine from center to center later on tonight if you need that info.
Thanks, that’d be awesome. I was told that the 3T pads should match up, but I’d rather be certain before I drop $ for a set
I got a pair of Uberhunds at an amazing price, but sent them back because it was not disclosed that the pad cups had been swapped out. The cups were Vision cups, so you could check them out also. I didn’t like how the cups sat on the bars so that could influence your decision.
Looks like 25mm center to center.
