You know, it’s funny - in doing some searches about tubular tires it became apparent that Tufos were extremely popular with members of this forum back in '04 and '05. It actually appeared that Tufo was the tire of choice.
Regarding the past couple years of discussion about Tufo and the greater RR, can anyone give me any idea how much slower a Tufo (S33 Special, S3 Lite, whatever) is alleged to be compared to a Corsa CX or other quality tire? Are we talking 15 seconds over a 40K – or is the difference significant?
And, who still races on Tufos?
Thanks,
John
According to AFMs testing here:
http://www.biketechreview.com/...ire_testing_rev6.pdf
…the best rolling Tufo he tested was the “Race Lite” which had a calculated flat, smooth surface Crr of .00322. The Vittoria CX tubular tested out at .00296. This makes for a difference of .00026.
For “real world” surfaces, he’s found that the Crr is typically higher by 50%, which would give a Crr difference of 1.5 x .00026 = .00039
OK, what can we do with that? Well, if we know the total mass supported by the tire and the speed traveled, we can figure out how much power is needed to overcome that difference.
Power = Crr * mass * gravity * velocity
Assuming a total mass of 85kg and a speed of 10.3 m/s (i.e. 23 mph), we get,
Power = .00039 * (85 kg) * (9.81 m/s^2) * (10.3 m/s) = 3.3W
The “rule of thumb” is that 5W is worth ~0.5s/km, so in this case it would be 0.33s/km of time difference, all else being equal. That would equate to ~13s over 40km. So, as you can see when choosing between these 2 tires, it’s not a huge difference. Then again, the other Tufos on the list (Elite jet clincher and S33) are much worse in Crr. For example, with the S33 (Crr = .00467), you’d be talking a difference of more like 22W and 2.2 s/km. That’s almost 1.5 minutes (1:28) over 40K.
BUT, what’s the difference between those models of Tufos and an OPEN Corsa CX with a latex tube (Crr = .00261)? For the “Race Lite” model, the “real world” difference would end up being .00092, and the power difference for the above case would be 8W. That translates to ~0.8 s/km, or 36s over 40K. For the S33 model, the difference would be more like 27W and 2.7 s/km. That’s almost 1:48 over 40K.
You can be the judge of what’s “significant”
