What sort of pressure should I be running in 25mm tubs? Its been a decade since I last used tubulars, and that was in the bad old days of way too much PSI. I haven’t even used inner tubes for the last 5 years.
80kg system weight, pre firecrest 808 fwiw.
Thanks heaps
I’m running 100 psi with my 25m Corsa tubs. Sometimes 110 on perfect roads.
The Silca tire pressure calculator says 91/93.5 psi for front/rear, worn pavement, road bike, 80 kg system weight. Start here and adjust a couple psi up or down.
I am 7 - 8 pounds heavier than you and with that same setup on the Tri bike I ride 110 front and 105 back. I have played around a lot and my this is where I subjectively feel the best and fastest. Decent roads and 1000 ft of climbing per 20 miles.
for an additional suggestion the Flo air pressure table 25mm with average pavement… 88psi so this seems to be in line with Silca. The key to Silca is the actual external width of the inflated tire, but they do not have a rating for tubulars but assume similar to latex tube. I think either source is a reasonable starting point. As the ST experts here have said before it is better to be on the slightly low side then on the high side of optimal. Even slightly too much pressure has a significant penalty in CRR due to breakpoint inflection (hockey stick graph) the slope increases dramatically after the breakpoint.
