I am 6’6" tall. 200lbs, plus bike. That’s probably 220lbs.
I’m trying to find tubeless race tires for my Cervelo P5-6 with new Zipp 808s. One issue I have is the clearance of the brakes because I can’t fit a tire greater than 25c.
I just took the tire from my wheel, and the 808s are hooked. So, it seems from the website (below link) from Continental, that I can go as high as 109. That should be sufficient.
How do you know what is the right PSI? Do you just experiment? I’m rather new to tubeless and I appreciate that–with tubeless–you can ride lower PSI; but, how much lower. Maybe, I’ll try 90 and just see how it feels. But, unless there is some Pro Tip metric/chart, then I’m afraid I’ll just be guessing.
It’s likely your tires are at least a few mm wider than 25mm when mounted, so worth it to actually measure IMO. 90psi is almost certainly going to be too high for you.
