if it ain’t broke, and you aren’t chasing AG world championships, don’t fix it. just keep running tubes is my 0.02.
I’ve tried switching to tubeless twice. Once in 2020, and once in 2023 and both times i just went right back to good old latex tubes within 6 months or less. the hassle of dealing with sealant was a deal breaker for me, and i had some flats that didn’t seal (when i almost never get flats with tubes). its so annoying to track when you put sealant in, break a tire seal to check how much is in there, worry about how much you’re putting in…spend money on a new pump, sealant, sealant injectors, dealing with mess of it, etc.
Good clincher tires are right there, RR wise, against tubeless, unless you are a marginal gainer worried about things at that level. but most of us, our lives are no different if we finish an IM in 12:30 or 12:28. Testing is not even clear that you must be tubeless to be faster. Some sources say the penalty of using a latex tube vs. sealant is a wash, so if you get top TLR tires and put tubes in them, you might not even have any real measurable RR penalty. Self-sealing flats and ability to more easily run tires over 32mm, is really to me the only tangible benefit of tubeless. but if you have good tires at proper pressure and don’t get a lot of regular flats with tubes, the self sealing thing (at least for me) was sort of a wash, not a huge benefit.
You’ll get different guidance on what to carry, but ultimately you have to carry some sort of spares. tubeless does not eliminate that. either the same array of things you do with tubes, or swap out the tube for a plug kit, but you still need all the rest. and, doing a plug out on the road when you’re 50 miles from home is SUPER stressful. tubes, you can practice endlessly changing them so you’re good at it. Unless you’re willing to repeatedly mutilate your tires, waste plugs, and waste sealant, you can’t practice plugging. The first time you do it will be in a high-stakes moment, hands shaking covered in sealant. you’ll be standing there about to stab your tire wondering what you’re doing with your life!
I don’t oppose tubeless categorically, to each their own, but don’t let the industry convince you that you have to go tubeless. if you’re comfortable with tubes and don’t have any problems that you’re looking to fix, just keep running latex tubes at proper pressure and you’ll be 100% fine and fast.
