So I got a pair of Bont Vaypor+ cycling shoes because of the heat molding capabilities and because my feet tend to go numb on bike rides. I figured having a shoe that was heat molded to my foot would maybe aide in circulation and help with the numbness.
So I followed all of the instructions on heat molding these shoes. 160F for 20 min with no luck. These shoes don’t seem to loosen up at all with the heat molding. The carbon is still hard as rock after baking. They haven’t conformed to my foot at all. I even went out and bought a couple thermometers to confirm that my oven is calibrated correctly and it is. Anyone else have experience with this?
The shoes never go soft, just slightly pliable. If there’s a spot causing a problem, identify it before heating and then work on that spot with some solid pressure using thumb or back of a screwdriver etc. Pre heat the oven and when you remove the shoes work quickly. If you wear thick socks and place all your weight on the shoes with knees bent it helps. You may have to mould a few times to get a perfect fit. It’s worth it.
The carbon doesn’t mold, the foam liner under the insole but on top of the carbon molds to the foot. .
Well I think it does.
"The base is made by hand by sandwiching cross weave carbon and uni-directional carbon fiber which is** embedded with epoxy thermo setting resin**. The fibers are hand laid in the matrix according to the strain they will have to bear. "
I’ve gone through the heat molding process with my low end Bonts and after trying the oven, had much better luck using a heat gun. It took way more heat than I expected to. You want to have your process completely figured out as the epoxy setts up really fast as it cools. You’ll need some “shapes” on hand to press against the sole or press the sole against. Thick dowels, screw driver handles, balls…It may take several tries to get the shape you want.
Well mine don’t get the least bit pliable. And even if I take them out and immediately work on them with the screwdriver, they don’t give one bit. I’ve attempted molding them 4 times now with no result.
I wouldn’t go up in temperature but apparently it’s ok to extend the heating time. I read that somewhere. Apparently if you try to warranty the shoes Bont can tell if they’ve been overheated. I’d try re moulding again after an extended heating time. If you can’t get the arch low enough it might be possible to shim the insole a little. If you have really low arches or flat feet you may never be able to get the arch low enough. I’m not an expert but had to mould a few times to get a fit I was happy with and did a lot of googling. I was seriously considering giving up on them until I went back to using my old shoes for a few rides!
I have pretty high arches. I’m just trying to get the shape of the arch right. But like I said, It’s not moving one bit.
My arches are extremely high too so I heated the arch area pretty specifically, slipped the shoe on and then put my whole weight into forming the arch area against an arched shaped piece of wood. It took several tries to get the shape just right.
Do you know your oven is really getting to 160? Ovens can easily be 10 or 15 degrees off… do a turkey thermo or such to double check the temp at the location you are putting your shoes.
