Trimax crank and Stages Power meter combination work?
My crankset is Vision Trimax. If I install the Stages power meter (left side only), other than it looking odd, does it work? Any balance issues weight-wise? Any suggestions or recommendations? Thanks in advance.
Any comments or suggestions?
John,
Is the FSA model crank arm that Stages sells even compatible with the Trimax Crank? If so, I wouldn’t worry about “balance” or color coordination. On the other hand after reading a large number of complaints regarding problems with computers especially wrist models having problems picking up the Stages and knowing the inherent disadvantage of single sided power meters, I’d go for something that measured the output of both legs rather than just my left leg.
YMMV,
Hugh
John,
YMMV,
Hugh
Thanks. Will look at other systems and do some additional research then.
