I’m almost sure the 23mm Conti will measure 25mm on the wheel.
Not the tubular version! That’s what we tested, the Conti Pro Ltd doesn’t come in clincher.
Sorry I’m confused and not sure what you mean - the Conti Pro Ltd tubular in 25mm (it’s not 23mm) measures up at 24.6mm when installed on a Pro3 trispoke, at 90psi.
I have heard that the pro’s dont actually get much in the way of kit, or at least some of them…
somthing along the lines of a couple of sets of kit for the season and one TT suit, the bikes in a set format( which they will have to give back at some point) certainly some pro’s swap in their own stuff like shoes and have to wear over shores to hide the branding, with TT bikes, i think they get the bike with a generic wheel set and swap in their oven preferred stuff, or even the only stuff they can afford ie a tri spoke they have had for years.
You couldn’t have a 90mm trispoke and I don’t think in British TT you can use the “D” version of HED’s either because the “open window area” of the wheel is not enough area.
Reach your hand between the spokes and measure that. If it’s less than XX cm^2 or something…can’t use it.
So, spoked wheels can get deeper than a trispoke due to the area the spokes present.
You’re right - it’s 45% (not including the hub) which limits a normal deep section wheel to about 102mm, and if you get a HED 3 then it’s about 68mm max before adding in the spokes tips it over the edge.
A lot of teams used tri spoke front wheels today for the team time trial at the TDF. Do they know something we dont know?
Since Lance days teams have been riding Specialized/Hed tri spokes when not sponsored or labelling them Prototype especially Sky who have the budget and test for the fastest products. Shimano now make a comparable fast wheel so they don’t have too. https://www.bikeradar.com/...sky-pinarello-graal/
That article is dated 2010, ketchup!
Ummm that is my point that Sky has been testing and using the fasted non sponsored wheels being tri spokes since for ever. As I state Shimano now make a tri spoke and they use a sponsors wheel. Getwithit!
So supposedly H3D would be better/worse than Pro 3spoke at moderate-high yaw?
I wouldn’t want to speculate - but you’d need a narrow tyre for it to work as it’s based on the previous version narrow rim. Over a decade back I extended a HED3 narrow rim wheel out to 68mm to hit the UK time trial limit, and made sure the fairing was wide enough to cope with a 21mm tyre as that’s all I had at the time!
Maybe for smaller budget teams back in the day or low budget pro continental teams may operate as you state. My mate went to school with a current pro at the TDF and he gets given endless amounts of kit he gives to my mate. All the teams at the tour at least will be using sponsors equipment and there is a lot of it. Have you seen the team busses?
I am talking about a recent/current situation, but yeah I guess it it will depend on the rider / team, I supose Sky would be pretty good for hoanding out kit etc, although that might have been rained in as Ineos.
Wow, so a pro3 is faster than a 100mm wheel if yaw stays below 10deg.
Does the HED H3+ test faster or slower than the Pro3? I’d be curious to see a how the H3+ with 23mm tires stacks up.
Btw, how do you weight drag in your charts? Equally for each angle?
No it’s the opposite - the TITAN is faster than the Pro3 at lower yaw angles as the drag is higher. At greater than 10deg the Pro3 is faster (lower drag - red line) but the weighted average makes them very similar, within around 1w using the tyres stated.
The weighted average is on our website under the AEOX disc data page, click on Aero Testing Data and then the AEOX disc vs a Super 9 etc and there’s a full explanation of how we set up our wind tunnel experiments (with photos). You definitely don’t want to take a straight average over the whole lot.
Curious as to your opinion on what 19mm tubular people are using in the UK on The hed trispoke? (Also 12 spoke shamal)
Taking mere mortals who have to buy retail!
Thanks,
Maurice
I’d assume clinchers in an aero size for the old HED trispokes is near impossible to get.
I’ve got an HED 3c tub. Haven’t riden it yet, as it’s an expensive race tire…but I glued up a Vittoria Pista G+ to it. We’ll see if it lives. I’d not run that though unless it’s good roads. If roads aren’t good, I’d likely run my road bike clincher wheel up front instead with a GP TT and latex.
I ride exact same 19 mile route every week and pace is about 20-22 mph. It’s a mix of flat and rolling hills. One hill is about 4-5% grade 2/3 mile long.
Whenever I switch to 808, I feel like someone is pushing me from behind, so I stopped using tri spoke. I haven’t used it for a year and maybe I will try again soon and see how it feels.
