Tri Shorts with Fleece Pad
Hi All,
Racing Ironman and 70.3. My favorite old Tri Shorts have started to wear a little thin in the lycra areas and i have been searching for a replacement pair for sometime. My current (2xu) have a fleece pad and i find this to not cause chafe on the run. I have purchased several newer style Tri Shorts (with a foam Pad) such as 2xu, DHB, Zoot and find that these all chaffe on the stiching on the edge of the pad against my skin during the long run. I alawys ended up going back to the fleece pad shorts for this reason but they are falling apart now… (IM OZ is in 8 weeks and i need a new pair).
Can anyone help me (point me in the right direction) find a brand that is still using a fleece pad? as said earlier, i have purchased 3-4 new pairs but they all cause me greif on the run… its getting a little expensive and retire those to swim trunks…
thanks in advance
Phatboy
I believe Skinfit makes a tri short with a fleece chamois.
Desoto Mobius is what I use with a Fleece Pad
I think the Carrera does too.
+1 De Soto Carrera or Mobius trishorts.
https://cdn.shopify.com/s/files/1/1135/1552/products/Men_Invisipad_02_64951ffd-e388-4a37-857d-a8340f059f9b_1024x1024.jpg?v=1578698010
If you are looking for something in Aus, there are some older 2XUs on eBay: https://www.ebay.com.au/itm/NWT-2XU-Mens-Small-Active-Tri-Short-Triathlon-Black/184688304494?hash=item2b0047e16e:g:FV0AAOSw88xgO-XZ
Race in a Speedo.
Cobb also makes a fleece tri short.
Thanks guys, appreciate the assistance. will look into the recomendations
