I have a QR PR5 and looking to do a few upgrades to try to increase my efficiency and gain a few watts.
Any recommendations? My bike is a stock di2. I added a power meter since then. Have a set of zipp 404s.
I need to change out my BB currently. Thinking of getting a steel BB. Any recommendations?
Wheels Manufacturing angular bearing is a good and affordable bottom bracket choice. Easy gains are tire choice, chain and lubes. What race tires are you using? Which lube and chain? Easy watts are waxed chain (Silca is a good choice) and good tires, the right width and pressure for your wheels.
Best Seconds per $ is probably latex tubes. Personally I’m not a fan of the GP5000 for ludicrously outdated bad experiences on some GP3000s, and so I always use Vittoria Corsas. But the latex tube is where the magic happens.
Aero helmet will give you the same sort of benefits as a deep front wheel relative to a standard one.
Then you’re probably looking at kit choices - sleeved skinsuit vs cycling top is huge difference. Not saying that you are wearing baggy cycling tops, but it’s amazing seeing the million dollars of top of the range uberbikes that go past when you are marshalling or spectating sitting under people wearing parachutes. So worth ruling out.
Chain - I’ve started waxing mine in last few months. Feels smooth, sounds smooth and love the lack of dirt. But the watt savings are in the tiny margins based on the data / my personal experience. It’s actually easy to do and there’s lots of reasons to do this, but apologies to Josh@Silca - aside from those at the very front of the field, watt savings aren’t the justification.
Do you have a coach? For vast majority of people, a coach is the single most cost effective way of getting faster. And yet the lure of ceramic bearings, oversized pulleys, $1500 bars seems way way more attractive.
I just order a pair of continental gp 5000 for my race tires. My chain is currently a standard ultegra chain. I have been using white lightening lube.
GP5000 good; as others mentioned, Latex tubes for sure. Slice has a great selection with aero valve stems as well. White Lightning not very good, per FF. Molten Spped wax or Silca (my fav) are far better.
Define ‘worth it’.
Surprised no one has said disc wheel (or wheel cover).
I don’t currently use one, but it will certainly be faster than your rear 404.
These are some of the high impact items for your bike. But cost is the key limiter…
Continental GP 5000 tiresLatex tubes
More aero front brakeWaxed chain
CockpitDeeper front wheelDisc rear wheel
What about a front hydration system and mounting bottles behind the saddle? Not sure what distance you’re targeting but it would keep you aero. I went with the aeria system on my PR5 (rim brake) and it cleaned up the front end nicely. Not sure what type of aero gains you would get but every bit helps.
Solid advice.
Adding:
Baby powder your latex tubes. I have no idea what the right amount is.Helmet? Get your head down lower by whatever means necessary.Take bar tape off.
Ahhh go figure. This will be an easy change! Thanks for the article!
Yeah, well I started my lube journey with White Lightening as well. Even if you aren’t ready to wax yet, there are plenty of better performing drip lubes.
