I was just professionally fitted for a Cervelo P2C. My question is, the stand-over height of the top tube is fine - no problem there. But if I’m riding and need to unclip to put a foot down, I need to move off the saddle to do it. Also to get it started, I clip one foot in, get the bike moving, then I can get on the seat to clip in the other foot. Is this typical of these bikes? When I contacted the fitter, he indicated that it was, but I thought I’d get some other opinions. Do I need to lower the seat? The fitter told me that lowering the seat might result in non-optimal body angles.
Also to mount and dismount, it seems that due to my flexibility or lack thereof, it is easier for me to swing my leg over the handbars with the bike tipped at an angle versus going over the seat and the seat attachment that holds extra bottles.
Finally the bike seems to use a compact crank set up as standard (50/34) is this also typical? I’m more use to 52/42/30 on my road bike with most of the time in 52/42. Since I posted the above thread in RoadBike Review, I did get a reply from Cervelo about the compact crank: …Thank you for your interest in Cervélo. The Gossamer compact crank is the stock item on this model. There is no factory option for any other crank. If you wish to change the crankset to a standard 53/39 configuration please discuss this possibility with your dealer.
We have had many requests for the addition of a compact drivetrain on a higher level TT/Tri bike. Events like IM Lake Placid have no doubt influenced this trend. We have obliged by incorporating this feature into the P2C Ultegra build for this year.
Once again, thank you for your support.
Sincerely
Tim
Cervélo Customer Support
Thanks in advance for any comments,
Paul
