Trek Speed Concept and Front Light Options?
Hi all,
I have the Bontrager 800 ion lumen. What’s the best way to mount it on the front of the Trek speed concept? The clamp that comes with the 800 ion doesn’t fit the bars?
Thanks
Hi all,
Thanks
Using our front mounted bottle cage with the clamp accessory would work, but besides that, the other option would be to use the mono extension to attach it to. Since you have the Ion 800, you should have the Sync-V2 light mount which can swivel - it’s not a perfect location, but it works!
Hi Mitch, random question for you: on the current year Trek 920, what is the bottom bracket standard that is used on the frame’s BB shell?
thanks,
Greg @ dsw
Hi all,
Thanks
I saran wrapped that light to the bottom of the monobar once, it worked really well.
thanks,
Greg @ dsw
English threaded BB 68/73mm
So the shell is 68mm wide, but you can add a spacer to get 73mm? So one can mount a road crankset on the 68mm wide BB shell? Thanks again.
Correct
