Travel trac parts?
I have an older (1999) Travel Trac fluid trainer that I dusted off for use this Winter. I need to replace the rubber feet on it. I called Performance, no luck. I cannot find a site for the company itself. Has anyone found replacement parts readily available anywhere? I can do without the feet, but it tends to slide without them. Alternative may be just to wrap the ends with bar tape.
Thanks.
Thanks. suggest to check if the parts are the same on the Elite trainers. I have an Elite fluid trainer and have noticed (in a Performance bike shop) some have identical design and identical electronics.
