My current bike is a bp stealth copy with 73 degree seat tube angle and 56cm virtual TT. The reach on this bike, as best I can measure, is 400mm. I have a forward post (although not that forward) and my adamo race all the way forward. With this set up I am 5 cm behind the bottom bracket. From the bottom of the head tube to the bottom of my stem (which is 100mm by -6) it measures 165mm (actual HT is 120mm, yes lots of spacers), with 11cm of pad drop. I am about 6’1" tall.
With a lot of the bikes I’m looking at the reach is much longer than 400mm when the head tubes get to where I need them to be. Now, if I buy a bike with a reach of about 450mm and ride with the nose of the saddle even with the bottom bracket, have the same stack and stem length, I should have the same fit coordinates, correct?
My question is, if I do switch to a steeper angle, is there going to be an adjustment period going from 5cm behind the bottom bracket to even with bottom bracket? I understand I should be able to drop the front also. Is there a rule of thumb for however many cm you move the saddle forward you can drop the front x amount of mm. Am I completely off here? I just do time trials, so no running afterward. My position feels good but I haven’t ridden steep so nothing to compare to. I’m not opposed to riding steep. Right now the closet thing I’ve seen is the Slice in 60cm size.
