This is something I am really curious about because for the past few decades I have taken all approaches from not training at all to training right through the cold. Lately (as I am older) I do more of the former. However, part of me wishes I didn’t as it takes me weeks to get better sometimes and this ‘sitting around’ seriously effects my fitness and my mood. When I ran track and xc all the way back to HS, I’d run through it, and I would get mixed results. Sometimes subsequently I would end up with Pneumonia or Bronchitis and would be forced to stop training. In other situations, when I would train through a sickness, I’d get better and have had some of my best races while still sick - both in HS and early on with Triathlon. There are times where I haven’t gotten sick for a few years, and years where I have gotten sick almost every other month. I’d say on average, I get sick more than most and for longer than most. Most colds take 1-3 weeks to get over AND, in many cases, this is with FULL resting.
I remember hearing once that ‘if it is neck and above’ to train. If it is below the neck (lungs), to stop. I have adhered to that in the past, however it comes with two problems for me. First is, there are times when I have ‘been about to be sick’ and had a slight sore throat, but, took the proper early precautions and didn’t become sick. Can think of a lot of instances where my wife got sick and I didn’t because I decided to rest, eat super clean, etc… I can also think of many times where I thought 'maybe it’s allergies (and, it wasn’t), continue to train, and get a really bad cold… I do truly believe that this is the most important time when you are sick to defeat the cold early (or, make it significantly shorter) since you innate immune system still has a chance. Second problem with this logic (of above the neck / below the neck) is that my colds almost always seem to be sore throat, then stuffy or nose, then cough (and in that order). If I piss off my immune system more somewhere along that process, then it starts to ‘repeat’ and in addition when the cough comes, it is usually much worse and lasts a lot longer. There have been times where I have actually skipped having a cough altogether and just went throught the first two symptoms. However, this is very rare… In addition, to make matters more confusing, there have been times in the past where a little bit of training toward the end of a cold helped me when I had a cough and/or stuffy nose, as it made the mucus expulsion more productive…
I’m curious as to what other people here do. I’m also curious that if any of you are doctors, might do - essentially what does the science say? All my docs are runners so they are indifferent. If I tell them I want to run, they’ll just say, ‘play it by ear’, or ‘go ahead’.
I am alas asking this question here, because, yes, I am sick again… A summer cold (which is very rare for me), and it doesn’t seem to be that bad. Part of me wants to train. And, the other part isn’t sure. I’m sure a lot of these varied results has to do with various factors, perhaps the most of which, might be the strand of cold/virus/bacteria I am dealing with (which, one is almost never sure of…). I do have to say I am quite jealous, when I see others train through colds and almost always get better no matter what… Wondering what I could be doing wrong…
Thanks for reading…
