Training Through Periostitis (Shin Splint)?
I’m in marathon training and have developed some pain in my left tibia over the past few weeks (think it happened specifically when I did a long run in lightweight racing flats that I was considering for the race). I went to the ortho to rule out a stress fracture and an MRI showed periostitis, which I guess is just a fancy word for shin splint (but no stress fx/reaction!). The doctor recommended a lot of aleve and some calf strengthening exercises (putting ankle weights on my feet and lifting the foot up and down with the shin). He said I only needed to stop training if the pain became bad enough that I limped while walking.
With that in mind, I’m wondering if anyone has recommendations for managing or recovering from this through my training? A couple common recommendations from googling that don’t seem too whacky are ice massage with a dixie cup and toe taps while standing. Anything else that you recommend? Will wearing compression sock/sleeve either when I’m running or resting or both help? What about PT/massage?
Thanks!
Eric
Most marathon or experienced runners don’t experience shin splints - more typical in “new” or returning runners. Which are you? Overworking the tibialis anterior is generally the cause, and rest, ice, compression sleeves (they do seem to help people say for reasons I’m not sure), running on softer surfaces, NOT overstriding/shortening cadence, etc. all help. You can run through them technically, especially with a neg MRI.
Thanks!
Eric
The term “shinsplint” is actually term used to describe various different causess of pain in the lower leg. These can include tibial stress fracture, anterior compartment syndrome, and tendinitis (possibly with associated periostitis).
I personally don’t see how strengthening the calves would help. That might actually cause more muscular imbalances. It would be of greater benefit to strengthen the tibialis anterior ( the muscle which dorsiflexes the foot and antagonizes the action of the calves) to reduce muscular imbalance.
I am an experienced runner, and never had this problem before. It started right after a long run on pavement in some 5oz racing flats. With hindsight, I acknowledge it was dumb to do this. I just want to manage it as best as possible between now and Boston.
I was wrong to say calf strengthening. The exercise he recommended is sitting down with your feet dangling and putting ankle weights on your feet, then flexing the foot up-and-down.
Gotcha. Nothing wrong with a 5oz racing flat - just not for a long run if not used to it! I personally wouldn’t run a marathon in them (especially Boston, which I’ve done 3 times), simply moving to something in the 7.5-8oz range makes a huge difference on the lower extremity for a marathon, especially the back half of Boston after you have been beat up/flying downhill until the girls at Wellsley.
In your case, since you apparently seem to know what caused them, had a hands on exam/MRI, you should be fine. Just put away the flats till after Boston for the shorter speedwork, 5/10Ks, etc. :wink: Best of luck if it is your first Boston!
OK, that’s better. That would work the tibialis anterior.
Stronger tibialis anterior will stabilize the foot landing, and it also may reult in strengthening the associated bony structures.
Great, thank you! Do you think massage/PT will help at all?
Won’t hurt, but will mostly only be helpful if part of your contributing factory is a posterior gastroc/soleus (which can then cause “overworking” of the anterior tibial).
