Training Peak/Garmin conect
Can we Sync or transfer , training information from training peak calendar to Garmin connect calendar ?
Thanks
I have my Garmin Connect account set up to automatically push my workouts to TP & Strava as soon as they are uploaded. DC Rainmaker did writeups on how to set this up.
TP - http://www.dcrainmaker.com/2014/06/training-automatic-connect.html
Strava - http://www.dcrainmaker.com/2014/08/automatic-mapmyfitness-endomondo.html
Hi, thanks but what I’m looking for is to transfer pm training plan from training peak to garmin connect calendar. I know the infos from garmin to strava or garmin are easy to transfer
TP → Garmin? Pretty sure that’s a no. If you have activities you could export TCX files and import them maybe.
Thanks
From TrainingPeaks to Garmin Connect no.
From Garmin Connect to TrainingPeaks yes.
Why not just use the TP calendar?
Yes I can, just try to have everything in one application
i recently ran into this as i wanted my TP calendar information on my Garmin watch under calendar view.
Used the TP Calendar sync function to my google calendar and was able to achieve what i needed.
I don’t know what you are ultimately trying to achieve but there may be a workaround.
If you simply want to have future TP data in garmin calendar then its a no go.
If you want everything in one app why are you using garmin connect instead of just TP out of curiosity?
I purchased training plan with training peak
If your plan is in TP then sync GC into TP and have TP as the one source. You won’t have the calendar on your Garmin but you can sync the calendar almost anywhere else and/or get a daily email with today’s workouts
How did you end up getting the data for the calendar onto your garmin device? What I really want is my training plan on my garmin device, but not to have to create said plan in garmin connect.
Thanks!
