Look, the functionality of the shoe has a lot to do with it. We don’t run in ski boots because they are STIFF and restrict movement. Lightweight trainers give most of the functionality of flats, with most of the durability and cushioning of the heavier running shoes.
I’ve been running a LONG time and have run 2:54 in the marathon (same course, different years) in both flats and “lightweight trainers” (Asics Gel-Lyte). The only difference was how I felt afterward. At 165lbs, I felt shredded by the flats. The trainers left me ok for runs days afterward.
Of course it’s important that the shoe adabts to the given condition and isn’t as stiff as a ski boot. But my point was that weight plays a role, even if only minimal. Under constant conditions, an increase in weight (shoe, legs, etc.) also requires you to do more work. Altough that difference might be minimal, wouldn’t it be possible that it becomes significant with the number of steps you take during a marathon?
To state that there isn’t any difference other than how you felt afterwards is your experience and opinion, but it isn’t very scientific. There are way too many variables involved to conlude that that is the only difference.
Farrell posted that “Lighter shoes make increasing leg turnover a hell of a lot easier though.” Looking at it from a biomechanics standpoint it should make sense. You can increase the leg turnover because the reduced mass reduces the moment of inertia (the resistance to the angular acceleration). Yet the running form plays an even greater role. Take a look at sprinters for example, they greatly reduce the angle at the knee. Doing so they reduce the radius of gyration which also reduces the moment of inertia, and are therefore able to increase their turnover.
I understand that turnover is not as important when running a marathon, but my point was the the increased mass of the shoe increases the resistance to the angular acceleration. Therefore requiring more work. Even if its just very little work per stroke cycle, I assume that it would multiply during the length of a marathon.
But I completely agree with you that comfort and shock absorbtion are the priorities in shoes. And superlight running shoes aren’t for anybody, a 180lbs person gets greater impact on the feet than a 120lbs person, assuming they have the same style of running.
