yes it will wobble/sway quite a bit, unless you replace the pins (both receiver and adapter) with bolts that you can cinch down (but even then it’ll still sway some); and
it’ll obviously extend the whole contraption out further horizontally behind the car ~ which isn’t such a big deal on a higher-clearance vehicle like a larger truck or SUV, but on a compact car it means you’ll more commonly risk scraping on any sort of sloped driveway or curb cut, epsecially pulling in/out perpendicular to the road crown.
I had one of the converters on a eurovan. It worked fine. I did a few road trips with 4 stupidly heavy family bikes to instill the confidence to put my race bikes on there.
It seems to get the hitch up a little and I’ve not had any problems.
However, when converting from 1 1/4 to 2, you have to watch out for compatibility.
Mazda has rated their hitch as a Class 1. I bet if you stick your finger in the receiver you’ll feel a little bump or piece of metal they’ve welded in there to keep you from being able to use Class 2+ hitches. Most 2" hitches are Class 2.
I didn’t know that. I ended up grinding down the stop to use the hitch, but there are Class 1 compatible 2" out there.
I had to do this with my Camry. the only issue I have is that some times it will bottom out in some driveways due to the carrier being extended out further due to the adapter. Sway not an issue.
Just got a class 3 (2 inch ) hitch today installed on my CRV for 175. Seems way more stable becaue it is mounted to my frame not my bumper. Not that much more expensive than class 2.
I’m worried that the converter will either not work, or allow a lot of sway. Have any of you used one of these, and if so, did it work ok?
Thanks!
Bigshoes
I have done this on one of my vehicles. this little contraption works pretty well for reducing the wobble. Search amazon for the:
Boone outdoor no rattle hitch stabilizer. aka the wedge.
sorry, I’m on a phone and having trouble creating a link.
Update - had a 2 inch class 3 hitch installed on my CR-V. Carted 4 bikes 400 miles over freeways and curvy mountain roads on my Softride rack. Worked like a charm.
