I have a very well-kept 54 cm 2003 Felt S22 I’m looking to trade for a road bike of similar value. Bike has less than 2000 miles. At the very least, I am looking for something with a good aluminium frame and 105 or better.
I’ll post pics in a day or two.
Here are the specs.
Fork Felt Aerofoil Carbon
Frame Material Aluminum
Hubs Alex ALX 320
Rims Alex ALX 320
Brake Levers Dia-Compe 188 TRI
Brakeset Shimano 105 Dual Pivot brakes, Dia-Compe 188 TRI levers
Front Brake Shimano 105 Dual Pivot
Front Brake Lever Dia-Compe 188 TRI
Rear Brake Shimano 105 Dual Pivot
Rear Brake Lever Dia-Compe 188 TRI
Components
Bottom Bracket FSA ISIS
Bottom Bracket Shell Width 68mm American
Bottom Bracket Spindle Length Unspecified
Chain KMC Z9900, 1/2 x 3/32"
Chain Size 1/2 x 3/32"
Chainrings 39/53
Crankset FSA Carbon Pro, 39/53 teeth
Front Derailleur Shimano Ultegra, clamp-on
Front Derailleur Type clamp-on
Handlebar aluminum tri bar
Handlebar Extensions Syntace C-2 Streamliner
Handlebar Stem Felt S-1.4
Head Tube Angle 73.0
Headset 1" integrated Tien Hsin
Headset Diameter 1" integrated
Largest Rear Cog 23
Number of Rear Cogs 9-speed
Pedals Not included
Rear Cogs 9-speed, 12 - 23 teeth
Rear Derailleur Shimano Ultegra
Saddle Selle San MArco Triathgel Azoto
Seat Post Diameter 27.2mm
Seat Tube Angle 76.0
Seatpost Felt aluminum micro-adjust, 27.2mm diameter
Shift Levers Shimano Dura-Ace SL-BS77 bar-end
Smallest Rear Cog 12
Fork and Suspension
Fork Crown aero
Fork Material carbon fiber composite w/alloy steerer, aero crown
Fork Travel Not applicable
Frame
Frame Angles 73.0 head, 76.0 seat
Frame Construction TIG-welded
Frame Tubing Material 7005 aluminum w/replaceable derailleur hanger
Geometry
Chainstay Length 40.5cm
Fork Rake 4.0cm
Top Tube Length 56.0cm
Wheelbase 100.6cm
