Hey, my kid is doing Track Nats this year, mostly IP, never ridden indoors.
Any real advantage at 48-50kph with tubies (Vit Speeds, Oro, etc) vs. Corsa Speeds or VF Records?
Also, if anybody has perspective on 333m concrete vs 250m wood, speedwise.
Yeah, I don’t have numbers at hand, but I’ve heard from credible people that testing indicates that dedicated track race tubbies beat road tubbies. This seems plausible having used them in person. Track race tubbies are insanely thin.
Wood is faster. And Carson is smooth enough you can crank your tire pressure up to crazy #s, 160 PSI+. Which the same credible sources tell me is the thing to do. 1-2 KPH or so faster for an IP, very roughly. Though Carson is on the slow end for a smooth wood track for whatever reason. Not a track where records are broken, typically.
Buddy of mine is on the USA Cycling national team and exclusively rides the Vittoria Pista Speed and Control depending if he is on an indoor or outdoor track.
I use Vittoria Pista on my race wheels and Corsa Speed on my every day wheels.
Wood is going to be smoother than concrete and probably a little faster. LA is higher banks and longer straights than a normal 250 (as I’m told) so have him ready for 45 degree banked turns.
The difference between high end tubular tires is usually small enough that it’s overshadowed by a good or bad glue job. Vittoria Mastik was usually the best, and a lot of it. For indoor IP I’d see if you can borrow a front disc from someone. That’ll be a bigger difference than any tire choice.
For Carson and IP I would consider three tires: Pista Speed, ORO or Dugast silk. The Dugast will be delicate relative to the other two. All three are very fast.
Front disc is a must for IP. I run 19-20 F and 23 R.
Tire pressures at Carson should be 200+. Mastik is definitely the glue you want to use.
Second question: 333 v 250 (Carson specific) - turns are tight and straights are long at Carson, so learning the line is critical. Most people turn in too early and then push high mid turn. What 333 is your home track? Time on the track is the only answer to learning the nuance of Carson.
Baton Rouge & Alkek, both near identical, decent concrete.
For now, just using Corsa Speed clinchers.
1/2 hour on Carson race morning might be all the time we can hope for.
-bobo
I’d try to borrow some tubbies if possible, if just for the pressure. Assuming equal-or-better aero wheels.
And if it’s only 1/2 hour, I’d recommend he spend time in advance watching YouTube videos of elite pursuiters on 250 tracks, particularly Carson, and how they enter turns. QKRTNU is right that if you hug the black line like you can on a 333, the forces you experience in the turn can get more fatiguing than if you just smooth it out slightly. It’s possible to hug the black, but if you’re going really fast you have to physically brace your body for the forces, and it just wears on you. And definitely do a few hot laps in the aero position in that 1/2 hour.
Edit: And I don’t want to be pedantic, but if using road or concrete-velo tires, be sure to wipe then down well before taking the track at Carson. Normal dust can make them slick, and lateral grip is very important, particularly out of the electronic gate. Ask me how I know.
Alkek is my home track, happy to help anytime you want to come out to train. Weekends more so as weeknights are very challenging for me to get out to the track.
I’ve ridden a handful of tires from tubular Vittoria Pista Speeds, Dugast silk latex to clincher GP 4000s2 there without issue. For race day pick the fastest tire for your setup and don’t think twice. For training, just pick a tire that you like and stay above the min. recommended speeds in the turns.
If you want any Oro’s let me know. I have 2x 19mm and 2x23mm
