Torque wrench recommendations please
So I was thinking about getting/replacing a torque wrench. I currently have (but not sure where they are, so perhaps no longer have) a beam-style torque wrench and at least one Richey torque key. At this point, I am going to assume that I am starting with a blank slate as I have not seen them for a while (multiple moves).
Cheapest option would be a beam-style torque wrench. Probably somewhere around $20 from Sears. BUT not very accurate.I could also buy a couple single-torque keys. This would cost around $40 for what I need now. I would assume that these are reasonably accurate. BUT just because I only need two now, that might not be what I need in the future.Amazon is offering the adjustable Evans torque key for around $20. I would assume that this is not very accurate.Park Tools has an adjustable torque wrench for about $100. They also have an adjustable torque key for around $65.Finally, I could buy a no-name or Sears torque wrench for around $55.Recommendations?
What torque range, low torque or high torque? I love this little guy. It is a Shimano product, and it comes with a case and bits. Super handy, especially for travel.
https://www.probikekit.com/bicycle-tools-and-maintenance-nc/pro-3-15nm-torque-wrench-set/10772556.html
That sort of range. Anything that you would typically find on a bike.
I have a few single-torque keys. One is a Bontrager, the other is by Giant and has several allen bits.
An adjustable torque wrench, unless very high end, will not be very accurate. Sometimes torque keys aren’t very accurate either. Beam wrenches are actually pretty accurate tbh.
cdi torqcontrol is what you are looking for.
I have used one of these for a couple of years and found it to be all I could want for bike work. It is sold under a variety of names and a WIDE variety of prices for the same tool. WIGGLE.COM has it listed as " X-Tools Essential Torque Wrench Set" for $39.43 total
Yep, I got the BikeHand version from Amazon for about $40. Maybe not 100% accurate, but close enough to avoid massively over-tightening something. And I don’t think super-accurate is needed for the stuff we’re tightening on bikes.
I love this thing. Had it for a few years. Picked mine up at REI so dividend discount at the end of the year helps too.
http://www.bikeradar.com/us/gear/category/tools/torque-wrench/product/review-effetto-mariposa-giustaforza-ii-2-16-pro-deluxe-torque-wrench-45314/
Silca Ti-Torque is $99.
https://silca.cc/collections/silca-tools
Search this forum and you’ll find my thoughts. Save your $…
I agree. Also, I don’t trust cheap adjustable torque wrenches. I’ve had 2 fail on me. Most recently it over torqued my pedal (vectors) and stripped the threads on my crank arm. I never had issues with my beam. For more precise work and lower torque bolts I use the park adjustable one.
My one and only torque wrench, so not sure what I could be missing. But, not sure what else I’d ever need either. It has served my basic wrenching needs very well.
https://www.amazon.com/PRO-Adjustable-Torque-Wrench-Black/dp/B0018CVSNC
Scott
I bought this one on Kickstarter awhile back
Very happy with it and I find every excuse to use it.
Never done that with another tool before
Not sure why. Maybe it’s the fancy packaging or that I like to put the tool together before using it?
With a conversion cheat sheet, this is a good/cheaper alternative i have borrowed from s friend.
https://www.amazon.com/Wheeler-Firearms-Accurizing-Torque-Wrench/dp/B0012AXR4S/ref=sr_1_2?ie=UTF8&qid=1512445299&sr=8-2&keywords=Fat+wrench
Venzo from amazon. It was like $45. I bought it 5 years ago and been using it regularly.
