Sorry if already posted, but I have been out of the loop for a while.
I have a shiv and bought the Aero Z a while back. Got injured so I took a break and never hooked it up.
Getting back into tri and wanted to hook it up.
I noticed Torhans still says it is working on a system to connect them.
Has anyone done it on there own?
I remember some discussion of purchasing tubing and connecting from the Aero Z to the bladder, but like I said a while back.
Any help would be great.
Thanks
This can work via a valve and Y connector. We have done it, some of you may have seen it on our display bike in Kona in 2014 at our booth. There are a variety of sites that sell these such as http://www.qosina.com/. (Just buy samples). What you want is a .8id/1.0cm OD connector and valve. The valve needs to be prior to the Y connector. If you just use the Y connector you might be sucking some air when the AeroZ is empty and you are now drinking from the bladder.
As far as us coming up with a kit, it is still in the works.
Hope this helps.
Hans
