Tire pressure sensor from SRAM
Real time tire pressure monitoring system coming soon(June 1) by SRAM for road and mountain bikes… Pairs to cycling computer and/or smartphone with an accuracy of 2%, 10 grams per sensor for $199…
https://www.quarq.com/product/quarq-tyrewiz/?utm_medium=email&utm_campaign=TyreWiz%20Press%20Release&utm_content=TyreWiz%20Press%20Release+CID_b0cc52e06c43005e19e0bed05ff10a48&utm_source=Email%20marketing%20software&utm_term=Learn%20More#sm.0013r2hyagoqfgc11h52cf1q059mu
That’s really cool. However, I don’t know how many people would buy it.
LOL…next thing you know Thompson is going to put a scale in their seat posts to give you real time weight so you know how fat you are at any given time.
LOL…that is hilarious…I’d trademark that quickly before you see it on Kickstarter.
Would be interesting for cyclocross. Let’s see if Wout van Aert and team use it for the up coming season, as he is the marquee guy for SRAM.
Pretty dang pricey. For mid ride use, seems to me that only knowing about a significant drop would be worthwhile.
Yeah DCRainmaker said sweet spot for that is 99 for the pair…someone wrote in the comments…“a solution in search of a problem” lol. I love gadgets but I can’t see myself spending even 99 USD for that…
The more I think about it, this is meant for riders running tubeless or tubular with sealant. Assuming you get a puncture that the sealant fixes, and you lost some pressure in the process, your computer can let you know you need to add air or in the case of a pro CX rider, get a new bike in the pits next lap. I think mountain bikers would use this most to quickly verify pressure before dropping into a gnarly section that could have them end up in the hospital.
For general road riding with tubed wheels…it doesn’t make sense.
Thanks for the heads up.
Doesn’t seem like it would work(fit) for my Hed C3’s or any Deep rim.
I’m not paying $199 but this would be pretty useful. Think about it, most serious cyclists are (rightly) obsessed with tire pressure but we actually have no accurate data on what pressures we are really using at any given time. You pump up to X but then drop by some unknown amount when you take the pump off. Then, you go out and ride for hours on tires we know lose some pressure over time even if they are not damaged in some way and we often ride in wildly changing temperatures which might affect pressures. Now, those who really care can know what their pressures are over the course of an entire ride and, since the data syncs, among other things it will make analyzing various pressures with performance easier. Some folks will be able to make great use of that data. And then there is the side benefit of knowing your tires are holding air before some critical time like before a high speed decent . . …
Way too pricey for most but a great little gadget.
An anal cyclist will check their pressure with a quality pump before each ride. A quality pump costs way less than $200, and it actually pumps up your tires too! You don’t lose pressure when you take the pump head off the valve unless you have a crappy pump head or a bent valve core. The “hissing” sound you hear is the pressure releasing from the hose of the pump, not coming out of the tube.
Tire pressure doesn’t actually change that much during a ride even with regards to temperature over the course of many hours. And even if you did…what are you actually going to do about it. Pull over and crack a CO2 just to add 2 psi? Or bust out a hand pump?
As per my first sarcastic reply…perhaps we should develop a seat post that also acts as a body weight scale. Because we don’t have accurate data on how our weight fluctuates mid ride as we sweat, drink, eat, and burn off calories. If you’re going to be that meticulous about tire pressure mid ride, then you also need to know exactly how much you weigh at that same point in time.
I had an unusually tough time on the last 20 mile ride of a full iron. When I picked up my bike after the race, the rear wheel was completely flat. I don’t know if it was going flat during the ride and I was too dazed to notice, but I’d have killed at that moment to know if I had a slow leak.
But $200? Nope. I’d do $50 for a pair.
Yeah, the only use-cases I can see are for pros. In cyclocross you could go in for a bike exchange before your pressure goes critically bad.
I could see a team car in pro road racing having a tablet with the tire pressure telemetry of all their riders, so they can be in the right place quicker for the wheel exchange.
But those are extreme edge cases. We’re talking Wout Van Aert and Peter Sagan.
As per my first sarcastic reply…**perhaps we should develop a seat post that also acts as a body weight scale. **Because we don’t have accurate data on how our weight fluctuates mid ride as we sweat, drink, eat, and burn off calories. If you’re going to be that meticulous about tire pressure mid ride, then you also need to know exactly how much you weigh at that same point in time.
That has interesting implications for things like Zwift racing. Monitor continuously through a ride and it would be difficult to just take a little pressure off the saddle during the initial weigh in.
…and the only other thing I can think is the data logged over time might be useful. You could conceivably use the data combined with logged power meter and “aero stick” data to then calculate what tire pressure gave you optimal rolling resistance. It would just be a convenience in that case, though.
I suppose that would be a valid case…assuming that this thing reads accurately while the wheel is in motion and the tire/tube compresses near the valve on every rotation. Seems like a cumbersome thing to apply to your tube just because you’re too lazy to manually record what your floor pump says before each run though.
I for sure wouldn’t want to use this while training on a normal tube. Can’t imagine having to unscrew this thing (and likely put it in my pocket) just to change a flat. I’m sure as hell not reapplying plumbers tape and using any tools to thread this thing back on a spare tube with a removable core on the side of the road.
Hello Tony5 and All,
Neat but too big … It is not so much the price that causes me to hesitate buying … but rather size and weight.
I do not know how to make it … yet … but channeling on the pocket size tire pressure gauges that have a graduated part that extends to indicate pressure …
https://static.grainger.com/rp/s/is/image/Grainger/1EZF4_AS02?$mdmain$
Price $2.27
https://s.hswstatic.com/gif/pg-parts.jpg
Perhaps this design with the little graduated part that is visible located in a streamlined clear valve extender weighing only a couple of grams.
It could be colored green in the acceptable pressure area to make it quick reading … and so you would not have to stop to read the tire pressure … for on the fly pressure data … the little pressure data stick could cover a small hole when in the acceptable pressure range … when out of acceptable range the little uncovered hole would whistle … giving you an audible warning of low tire pressure.
Simple, cheap, effective.
Another solution would be a very light graphene cartridge filled with Nitrogen located inside a self sealing tubeless tire with a pressure sensing valve that released the Nitrogen any time the pressure in the tire fell below a certain level. You do not really need to know the pressure … you just want the pressure to automatically remain optimum.
Or better yet … a tire with good Crr elastic properties that did not require inflation and would not flat … and throw away pumps, tire gauges, self sealing fluids, patching kits, etc.
Any thoughts?
What would be cool is the combination of both. You can loose a race for not taking into account the effect on real tyre pressure of weight loss due to sweating, farting or snorting. A must have!
https://www.dcrainmaker.com/2018/04/hands-on-quarq-tirewiz-cycling-pressure-sensor.html
I’ll bet you this was pretty easy for Quarq to develop. They already have their ShockWiz device for MTB suspension tuning which basically does the same thing. That is measuring air pressures and transmitting them to a phone. The form of it even looks similar. I’ll bet since they already had the tech it was straightforward for them to make what is arguably a simpler device, so there wasn’t much cost to them. Agree with DCrainmaker that $99 is probably about the right price, but I’ll be they don’t have to sell a ton of these to make it worth their while.
