Anyone know or use a 25m tire on their 2014 Cervelo S2?
When I look on Cervelo’s website, it does indeed say supports tire clearance of 25m, but I don’t know if they are referring to the 2015 S2 or the 2014 S2.
Shouldn’t be a problem.
Went out and measured my S2 (it’s a 2014), and the width between the chain stays is ~38mm - although I didn’t pull the wheel for an accurate measurement, but there is a lot of room between the brake tracks (stock R500s) and chain stays. There is ~5mm clearance between my 23mm GP4000s II and the seat tube.
Tire clearance should be the same on both S2s
I run vittoria zaffiro pro slicks 25mm on velocity a23 rims no problem on my 2014 s2
Damon has said that it clears the biggest of 25mm tires, which was closer to 27mm.
