If you want a wider “Q” factor you need to look at the cleat - they have dots on them. Depeding on what shoe you mount what cleat to will alter that. From there you can only alter your spring tension.
Okay, the 2.5 is inboard as you can see here. I have mine on the tightest setting (pretty clear where that is when you see it). It is still pretty light to twist out - I have not once ever come out on accident.
In this photo you can see the dots, there is one on the plastic and one on the brass to indicate a wider or more narrow Q Factor - I prefer mine on the lesser setting.
I have two sets of times that have just started doing that as well. It doesn’t really matter what tension setting they are on. One of the pedals will just spontaneously release. One set it’s the right and the other the left, too bad they aren’t the same model. Any other thoughts? I’ve pretty much taken the whole thing apart and not found anything that seems to be wrong. Oh, and the third set I still works great- so it isn’t a cleat issue.
Time pedals are notorious for this disengaging when the cleat begins to wear. I used to race crits on them and I was always popping out of them in sprints…enough times that I got rid of them despite having a great platofrm for climbing. I switched to Speedplays and have never used another pedal brand on the road
