The geezers are there more often and they complain more loudly than you do.
American Swim Coaches Association says 78 - 80. We were talking abot pool regulations yesterday, I’m reasonable certain that you can’t have a reional or higher meet in USA swimming if the pool isn’t at or below 80 degrees.
We had this same issue at the pool i use. ASCA recommends 80 or below, the water aerobics association recommends 84 to 86 and the arthritis association recommends higher than that.
We have warm water pool for the arthritis so the battle is between the water aerobics and the swimmers. I have pushed hard and we have come to 81 - 82 as the compromise. i check it every day. I am the swim coach and won’t hold a workout in water warmer than 82. We will be all technique that day, it sucks but th emembers know why and usually make their feelings known.
For my part I also won’t workout in water that warm. Although I have considered hammering anyway and when it’s time to toss the cookies just do so in the water and have the pool close for two days. Do it a few times and they might get the picture; although it’s quite a hard thing to do just to make a point.
I think it all quite silly, I get the arthritis part, those folks don’t do anythign hard enough to work up heat in their bodies. But for water aerobics they can get in cold water, they will be cold for abou 45 seconds if the coach is good. But if the water is too ot, there’s nothing you can do. It will always be too hot, too cold lasts for just a minute.
In your particvualr case it’s a shame, if they built the pool with lanes and what not, why thenmake it not suitable for swimming. If you are making a pool for water aerobics, do that, save the money for the lane lines and such.
The optimum design for a new setup would be a warm water kiddie/arthritis/physical therapy pool, a second well for water aerobics and a 5 lane 25 meter pool for swimming.
One of these days I’m going to go ahead and build one. i think I read it will run about 250,000 just for the construction.
Use the “asca recommends 80º” as ammunition in the argument, it might help.
