Thinking of trying Hoka
What you recommend for a starter Hoka shoe? I have been using a rotation of On Running, Skechers GoRun and Nike and I am looking to try a Hoka that isn’t excessively cushioned with no more than 8mm drop hopefully for tempo runs. I have no problem buying an older model. Any recommendations?
I like the Rincon, I think it’s 5mm? It’s also a little cheaper than some of their other models, so while I’ve read people don’t think it last as long as some, it can also be found for around $100. I used to wear the Clifton but I prefer the Rincon now.
I’ve been running in the Cavu’s for a couple years now and like them. They’re less cushioned than many of the other Hoka’s so you may want to take a look at those. I’m looking for something with a bit more cushioning so I"m planning to give the RIncon a try next.
Do they fit true to size?
I’d say yes, I get the same size I buy for most brands.
thank
Moved from Asics Nimbus to Clifton for training and Rincon for racing.
Personally, I find the change really natural however the Rincon is half a size bigger than the Clifton!!
I rolled the dice with the Hoka Gaviotas and lost. They felt good in the running shop. I even ran in them for a few minutes on their treadmill. There’s nothing like a road test and they just don’t work for me so I use them on my maintenance runs. It was an expensive gamble and makes me apprehensive to try new running shoes.
May I ask what you prefer with the Rincon over the Clifton? Clifton’s were actually going to be my next shoe purchase.
I haven’t used the latest Cliftons but compared to the ones I had I like the softer upper and the Rincón is overall more comfortable to me.
the rincon is fine. as a race shoe. i don’t think we’ll be racing anytime soon. the clifton is much more capable as a trainer, and the elevon 2 or the original bondi b reissue are my 2 everyday trainers.
Thank you.
Rincon is much better. I think Rincon is one of the best shoes they got. Really light and comfortable. They are true to the size for me.
I currently have…
Rincon 1 Fast Tempo Day
Clifton 6 Medium speed runner
Bondi B Re-issue Slow Mondays
Mach 1 Track and Intervals
Carbon Rocket race shoe
I usually run in Altra, and for tempo runs I have a pair of carbon rocket, really like them.
As someone who otherwise runs in shoes like Glycerins and Nimbuses, but also really likes Bondis and Challengers, I find the drop #s for Hoka a bit misleading. To me, for one reason or another, the Hokas run as if they had a lot more drop than the stats indicate. I don’t think I’ve ever liked another shoe that lists as little drop as the Hokas have.
I got the blue/yellow clayton 2 because I liked the colors and it was half price. If you get any older version definately get a size bigger because they shrink slowly over time. I usually wear a 46-7 but the 47 2/3 was perfect
The feel was closer to a regular shoe than I expected. Only a little bit ploffy the first couple of runs until your stride adjusts. They feel super comfortable and light not bulky as i was expecting… More like highspeed cruisers than barebone racers
The sole looks thick from the side but your foot is cradled so its not super high and still flexible. The feel rather comes from extra width which gives the extra contact surface area. You can just run without thinking about how your foot is articulating with the tarmac. I train at 4 to 4.5 minute kms and these definately made it more fun and less sore legs next day
Which Clifton? Because that matters a lot. The original up through the 3 was an amazing shoe. Then they screwed up the 4 & 5, but the 6 is supposed to be back to what a Clifton should be.
I have the Rincon and like it ok, but it’s not near as squishy as a good Clifton. Clifton has the perfect balance of squish and responsiveness.
If someone wants to try Hoka I’d recommend the Clifton 6.
There really is no point to try a Hoka that isn’t excessively cushioned. To expand their business Hoka One One had to branch out into shoes that compete with what I call the middle of the shoe wall. You walk into a running store, the shoes in the middle from top to bottom and side to side are the best selling shoes in the world. The shoes at the top or on the sides are there to satisfy all runners but their sell through (volume) is much lower than the shoes in the middle of the wall.
All that said, there is only one shoe you should try to start out. In the work I do it’s the one shoe that stands above all other Hoka One One shoes and it is actually moving closer to the middle of the wall every day, the Clifton. Like any shoe you’ll find on this forum a favorite model year of the Clifton. The Clifton has created it’s own place and for good reason.
  1. It’s light - It’s the shoe that blows away what light is. Look at it and visually it looks “Heavy” pick it up and you’ll be blown away by the weight.
  2. It’s balanced - The platform is really well designed from the beginning.
  3. It’s got the perfect blend of Hoka One One DNA - High sidewalls to keep your foot centered, a rocker that allows you to tap away at 85-90 rpms easily, Maximal cushion in a lightweight package.
I’m not saying the other shoes from Hoka One One aren’t worth trying, they are. There is no point trying any of them before you try the Clifton.
ok 5/6 or doesn’t matter just try it to see if I like it?
