The Cervelo P3 has a fixing bolt on the frame that seems to be totally useless.
I read that it was for aero bottles etc, but I cant find anyone who manufactures a product that utilises that bolt.
So I gave it purpose as an elastic band hook for the right shoe. (yes, I’m bored today)
Step one,
Find a crimp connector with the right diameter hole for the mount bolt
Zach - how hard was this to do? Had same set up on my slice, but was hit by a car and getting a P2 sorted for IMC in 2 weeks and need a flat storage solution.
Not hard. Just need to be patient and careful. Cut off the bottle holder on bottom, then mold away. Molded in a bottom plate to attach to the bottom bolt for security. Has held strong over several rides on bumpy roads. Don’t use it every day though
so you’ve never done anything longer than a sprint? or you did the mod solely for a sprint but wouldn’t use it in a oly
I was being slightly facetious but none the less more watts and time saved with shaving over 40k than putting shoes on - or at the least the same again…
Carson/LA - 1.5 to 2 hours north. Give me a few weeks notice and we’ll get you in. Right now we’re booked to late August, but that’s mostly due to lack of track availability, which is not typical. Lots of Nat’l level races on the track and the Crossfit Games using up facility time (yep, you read that right, the Crossfit Games take over the entire Stubhub Center for the better part of a week).
If you’re willing, I think it would be a really cool feature to show folks what attention to detail, and a little ingenuity, can do for an athlete. Fun stuff.
Sweet - that makes sense. Held by the bottom bolt alone?
I was talking to Trevor Wurtele about his bottle modification too - just using the bottle - and also have a friend with a much bigger brain than mine, plus a 3D printer, looking into making something “shiv-ish” for that space. All in this little turn around haha.
I will be doing the aero 30 mod (if necessary) once I get the bike put together Monday. Should be fun - hopefully a nice little upgrade for IMC time wise from last year.
Easier still, just undo the bolt slightly, loop the rubber on it, then screw the bolt back in. That’s how I’ve been attaching my shoes to the seat-tube for the last two years…
