Inspired by the massive one on bikeforums.net, I’ve decided to start our own.
Have: FSA OS-115 130mm stem
http://forum.slowtwitch.com/gforum.cgi?post=3122499;search_string=;#3122499
Want: Thomson X4 120 zero degree
I have a Ritchey WCS 4-axis 100mm stem.
http://www.ritcheylogic.com/dyn_prodfamily.php?k=355369
Looking for a 100mm FSA or Thomson stem
For sale, make offer.
New 110mm Specialized alloy stem from Specialized Transition. 31.8mm clamp, 1" or 1.25" steer tube w/shim. A bit of rise, but don’t know angle. I wish it was stamped on it.
Graphite 110mm stem, 26.0mm clamp, 1.25" steer tube. Slight angle (less than the above stem)
All,
Thought I’d resurrect this thread, as I went through the stem box this weekend.
I have a load of stems, 80mm up to 120mm.
Profile Aris, Vision, Specialized, Salsa, Bontrager, various rises.
Let me know if anybody is looking to trade or purchase.
I am looking for a 110mm 26.0 black
I’d love a Ritchey Wet Black.
i’ve got:
Ritchey WCS wet black 100mm 6 degree
Ritchey WCS wet white 110mm 6 degree
EA 70 100mm 6 degree
Ritchey (OEM)100mm 6 degree
Thomson X4 100mm 0 Degree
Looking for:
Thomson X4 100 or 110mm 10 degree (for my 29’er)
Thomson X2 100mm 10 degree (Roadie)
Ritchey WCS 120mm 6 degree (Cross bike)
Make me an off on all the stems I have listed
PM me if you got stems i want!
Willing to TRADE
Oval concepts R700 stem
Stem is 120mm with 1 1/8 and 26 (undersize claim) I used it with the A900 series aerobars USED
The rise is 84°
Great looking, reliable lightweight stem RBT® eliminates key fatigue failure point Triple DIN security at a very light weight Marine SS bolts reliability & no rust Blue Loctite® so bolts won’t rattle loose Bias cut & opposing bolts cradle carbon steerer for added safety 180º bar wrap reduces bar & bolt stress Finely finished edges cradle exotic bars Matt Black body w/ Pearl Silver front cap or Stack height = 40mm/26.0 120g/26.0x80mm clamp Looking at 90mm or 100mm
I’m pretty sure I have a Vision Sizemore 110/26.0 at home, mounted once for 10 minutes, then taken off. Never ridden. Let me check on that, and check what I need for my current build.
I have a fsa carbon k factor that is 31.8 and 100mm looking for same quality stem preferably black and silver that is 90mm.
Alright my stem fitting experiment has ended and here’s what I have left. All are 31.8mm bars, 1 1/4" steerer.
Pro PLT Carbon Stem - 110 mm, +/-10 deg
ARX Team Stem - 120 mm, +/-17 deg
Easton EA90 Stem - - 130 mm, +/-10 deg
Want:
Cash
Looking for: Easton EA90 Stem - - 110 mm, +/-10 deg
Have to trade:New Avenir 90mm…25 degree rise 4 bolt faceplate(fits 31.8mm or 26mm bar w/supplied adapters), cash
Bump
have:
bontrager race xxx light alloy stem, 2010, 110mm 31.8
fsa os115 stem, -17deg 110mm 31.8 carbon face plate
want:
-17 120mm stem 31.8
FSA OS-99 CSI stem in 100mm size ±6degree angle, 31.8 mm clamp
Would like to trade for same or similar in 90mm size.
Have: Felt 100 mm, 26.0 clamp, 7 degree rise (6061 alum)
Need: 80mm, 26.0 clamp, similar rise.
I have a Oval Concept R900 black Carbon stem ± 6 26.0 clamp 110mm length
I am looking for a comparable 80mm or 70mm stem, preferably in carbon
I’ll take a look tonight. I might have something in 80mm.
It’s not carbon though.
WTB
70/80 mm
1" steerer but can take a 1 1/8" have the shim
- 10 - 17 degrees
26 mm
I have stem for trade for it or buy yours, my stem is posted above
bumpity bump this thread!
any chance you still haev that 80mm or anything in 70 mm
looking for 1 1/8th with 26 mm and rise + 10 to 17 ish
chris
sometime this week, i’ll just post all my stems i’ll sell.
i think the shortest i have left is 90mm, but i’ll check.
