Testosterone, Carbon Isotopes, and Floyd Landis - an understanding of trhe basics
I understand carbon isotopes and differentiating sources of chemicals by measuring the ratio (I believe they use this for testing real orange juice versus fake orange juice as well). But, I am no so sure of what the differences in content is in the real world. While searching, I found this article which helps explain the basics in pretty straightforward terms.
This is a pretty well written article on the C12/C13 isotope ratio and natural and synthetic testosterone, by Derek Lowe who has a Ph.D. in organic chemistry. I have also included a response comment which indicates that it may not be so cut and dried.
For reference, C3 and C4 plants refer to plants that synthesize either three carbon or four carbon containing sugars from carbon dioxide and water (and sunlight).
http://pipeline.corante.com/archives/2006/08/01/testosterone_carbon_isotopes_and_floyd_landis.php#131076 http://pipeline.corante.com//title.gif « Hobson’s Choice | Main | A Law of the Lab: Yields and Variations » August 01, 2006 Testosterone, Carbon Isotopes, and Floyd Landishttp://www.corante.com/frontpage/email.gif
Posted by Derek
The New York Times broke the story today that the testosterone found in Tour de France champion Floyd Landis’s blood was not from a natural source. Just how do they know that, and how reliable is the test?
The first thing an anti-doping lab looks for in such a case is the ratio of testosterone to the isomeric epitestosterone - too high an imbalance is physiologically unlikely and arouses suspicion. Landis already is in trouble from that reading, but the subject of the Times scoop is the isotopic ratio of the testosterone itself. And that one is going to be hard to get away from, if it’s true.
Update: people are asking me why athletes don’t just take extra epistestosterone to even things out. That they do - that’s the most basic form of masking, and if Landis’s ratio was as far off as is being reported, it’s one of the odd features about this case. But the isotope test will spot either one, if it’s not the kind your body produces itself - read on.
Steroids, by weight, are mostly carbon atoms. Most of the carbon in the world is the C-12 isotope, six protons and six neutrons, but around one per cent of it has an extra neutron to make it C-13. Those are the only stable isotopes of carbon. You can find tiny bits of radioactive C-14, though, and you can also get C-11 if you have access to a particle accelerator. Work fast, though, because it’s hot as a pistol.
So, testosterone has 19 carbon atoms, and if on average every one out of a hundred carbon atoms is a C-13, you can calculate the spread of molecular weights you could expect, and their relative abundance. One out of every ten thousand molecules would have two C-13 atoms in there somewhere, one out of every million or so would have three, and so on. A good mass spectrometer will lay this data out for you like a deck of cards.
But here’s the kicker: those isotopic forms of the elements behave a bit differently in chemical reactions. The heavier ones do the same things as their lighter cousins, but if they’re involved in or near key bond-breaking or bond-making steps, they do them more slowly. It’s like having a heavier ball attached to the other end of a spring. This is called a kinetic isotope effect, and chemists have found all sorts of weird and ingenious ways to expoit it. But it’s been showing up for a lot longer than we’ve been around.
The enzymatic reactions that plants and bacteria use when they take up or form carbon dioxide have been slowly and relentlessly messing with the isotope ratios of carbon for hundreds of millions of years. And since decayed plants are food for other plants, and the living plants are food for animals, which are food for other animals and fertilizer for still more plants. . .over all this time, biological systems have become enriched in the lighter, faster-reacting C-12 isotope, while the rest of the nonliving world has become a bit heavier in C-13. You can sample the air next to a bunch of plants and watch as they switch from daytime photosynthesis to nighttime respiration, just based on the carbon isotope ratios. Ridiculously tiny variations in these things can now be observed, which have led to all sorts of unlikely applications, from determining where particular batches of cocaine came from to figuring out the dietary preferences of extinct herbivores.
So, if your body is just naturally cranking out the testosterone, it’s going to have a particular isotopic signature. But if you’re taking the synthetic stuff, which has been partly worked on with abiotic forms of carbon derived from a different source (see below), the fingerprints will show. (Update: yes, this means that the difference between commercial testosterone and the body’s own supply isn’t as large as it would be otherwise, since the commercial synthesis generally starts from plant-derived steroid backbones. But it’s still nothing that a good mass spec lab would miss). If the news reports are right, that’s what Landis’s blood samples have shown. And if they have, there seems only one unfortunate conclusion to be drawn.
Chem-Geek Supplemental Update: for the folks who have been wondering where exactly the isotopic difference comes in, here’s the story: synthetic testosterone is made from phytosterol percursors, typically derived from wild yams or soy. Those are both warm-climate C3 plants, which take up atmospheric carbon dioxide by a different route than temperate-zone C4 plants, leading to noticeably different isotope ratios. That’s where all the isotope-driven studies of diet start from. The typical Western industrial-country diet is derived from a mixture of C3 and C4 stocks, so the appearance of testosterone with a C3-plant isotopic profile is diagnostic.
Follow up comment posted on same site:
Bart Hall (Kansas, USA) on August 2, 2006 10:37 AM writes…
“synthetic testosterone is made from phytosterol percursors, typically derived from wild yams or soy. Those are both warm-climate C3 plants, which take up atmospheric carbon dioxide by a different route than temperate-zone C4 plants, leading to noticeably different isotope ratio”
I’m an agronomist and soil chemist by training. You don’t quite have it right. Yams and soy are indeed C3 plants (glycerol pathway), and they like warm climates, but C4 plants (oxalacetic pathway) are not temperate zone plants.
C4s such as maize(corn) and sugarcane are noticeably enriched in 13C compared to all the C3s, including soy and yams.
Where this gets interesting is that the standard American diet gets substantial amounts of its carbon from C4 plants, the Europeans get nearly all of their carbon from cereals, potatoes, and beet sugar, all of which are 13C impoverished compared to an American diet.
I don’t know the specifics of the Landis testing, but I would expect natural testosterone in an American to be 13C-enriched compared to a European. If derived from soybean and yam phytosterols, synthetic testosterone should be relatively LOWER in 13C than an American’s natural hormone.
Soybean or yam-derived synthetic testosterone should display an isotopic ratio much closer to the natural testosterone of a European, and if a European lab is flagging high 13C in an American as a sign of synthetic testosterone I think they may be missing an important factor.
My understanding (from what I’ve read on cyclingnews) is that the c12/c13 isotope ratio isn’t used on its own. The c12/13 ratio in the testosterone is actually compared to the c12/13 ratio of other hormones. I presume that is to account for dietary or other differences that may result in an unusual reading.
I love chemistry!
yes, that 's my understanding too. if the testosterone is different than other hormones in the body, then there’s a red flag for exogenous.
"Photosynthesis and carbon cycling: Terrestrial plants fix atmospheric CO2 by two main photosynthetic reaction pathways: the Calvin-Benson, or C3, and the Hatch-Slack, or C4. C3 plants convert atmospheric CO2 to a phosphoglycerate compound with three C atoms while C4 plants convert CO2 to dicarboxylic acid, a four-C compound. Carbon isotopes are strongly fractionated by photosynthesis and the C3 and C4 processes involve different isotopic fractionation, with the result that C4 plants have higher delta13C values ranging from -17o/oo to -9o/oo with a mean of -13o/oo relative to PDB, while C3 plants show delta values ranging from -32o/oo to -20o/oo with an average value of -27o/oo. Most terrestrial plants are C3, all forest communities and most temperate zone plant communities of all kinds being dominated by C3 plants. The native plant populations of North America and Europe are almost exclusively C3. Over 80% of crop plants are C3.
C4 plants are characteristically found in hot, arid environments: a selective advantage of C4 photosynthesis is more efficient use of water. Some crops of immense importance are C4 plants: maize, sorghum, millet, and sugar cane. The 13C value is a standard method for distinguishing the C3 and C4 plant groups and is used by plant physiologists to determine drought resistance in C3 plants, as well as to breed for improvement in this increasingly vital characteristic. "
So what is the acceptable deviation from the baseline ratio? I heard a Landis clip where he said something to the effect of “the CIR test only showed trace amounts of synthetic testosterone, and not enough to cause an 11:1 T/E”. Have any of the specific results of the CIR test been released? The CIR test has certainly been portrayed as a black and white deal, but it doesn’t appear to be entirely that way.
The ratio can be off by a factor of 3, or something like that, Landis’ test result was 3.99.
(Something like that, I’m being lazy and don’t feel like looking it up. The numbers are correct, but I forget the exact terms used to describe the numbers.)
