Terrain adjusted VDOT calculator?
Hi all,
I just run a fairly hilly HM and would like to use the result to estimate a VDOT and plan my next flat marathon training accordingly.
Two questions:
  1. Do you know of any VDOT calculator that would take into account positive/negative elevation? Or even better, a VDOT calculator that can take gpx files? My time was 1:27 with 500ft of positive & negative elevation (two big hills).
https://dl.dropbox.com/u/7663872/Screen%20shot%202012-11-19%20at%201.13.01%20PM.png
  1. I did it out of shape with really little training (15 mpw, these past few weeks :frowning: ) and a few extra pounds compared to my ā€œidealā€ race wait (153lbs vs. 146lbs). How do you take that into account to adjust your VDOT?
Thanks!
1:27 on ā€œout of shapeā€ training and 15 miles a week…
I give you a B+ on your back door brag… it could’ve been better (I also had just broken my femur the week before… for example)
In all seriousness… I think there is a translator in Strava that tells you your actual pace… but then again, strava numbers seem to be a bit high.
Good race.
Hi all,
Two questions:
Thanks!
Training peaks would give ou a normalized gradient pace, ie an equivalent pace for the run. You could multiple that NGP * 13.1 for an equivalent time on flat. You could get a VDOT from that. I don’t think the standard (free) edition it. The Premium version does. It’s great.
Strava will give you a ā€œGrade Adjusted Paceā€ for each mile. I do not know how accurate it is. You can add all the miles for total time. That is free.
For weight its 2.2 seconds per mile per pound, but you shouldn’t just lower your VDOT by 18 seconds a mile because you are overweight.
If you’re Vdot is 50 based on the run then its 50. It may go up as you lose weight but lots of factors apply. I wouldn’t make any adjustments, not even for terrain. Most people over estimate how much hills hurt them. Your 1:27 might be 1:26, but i doubt much lower and if you are starting a marathon training program with a base of 15 miles per week you re in for quite a bit of fatigue for a while anyways, so piling on miles and piling on intensity at the same time isn’t a good idea. Just use the the 1:27 time and when you race better or notice the workouts are much easier bump up the VDOT then.
The free version of TrainingPeaks will give you NGP but it will only be as accurate your GPS as elevation correction is a premium feature. If you want to try premium free for 7 days PM me :slight_smile:
Agreed. To the OP: remember that the whole reason that Vdot was created was to be a performance-based indicator of how hard you should be doing your workouts. Right now, your latest performance gives you a particular number. Stick with that number until you have gained enough fitness to perform better, and generally, gaining that fitness takes at least three weeks depending on how in-shape or out-of-shape you are. If you pick out a Vdot number based on what you think you ā€œcouldā€ do, you’re tossing aside all of the thinking behind Vdot. You might as well not use it at that point.
Thank you all for the advices. Strava’s Grade Adjusted Pace calls for a 1h24min25sec.
I understand now I shouldn’t make any weight or fitness-based adjustment, thanks! I’ll start with a 55 VDOT and make race-based adjustments along the way to the marathon.
