I tested in November 2022 - on the track in Copenhagen. 13 runs - testing helmets, suits, calf sleeves and position.
And January 2024 with WattShop in England - 1 day on the track and 1 day in the windtunnel.
It’s hard/impossible to compare Cda values, but it’s talk watt savings instead @45km/hr
Giant Trinity (same bike in all tests) with Cadex Wheels - GP5000 TT TdF tires.
Baseline in 2022 was Trimtex standard LD suit and Giro Aerohead helmet. Velotoze calfsleeves and Giro Empire with laces.
Baseline in 2022 - 303 watts.
Final result in 2022 - 290 watts (Met Drone, Box on chest, Castelli Suit, HUUB 2.0 sleeves, saddle height -2 cm, +4 cm reach and +2 cm stack)
Savings in 2022 - 13 watts.
And again the absolute numbers from 2022, can’t be compared to the numbers from the test with Wattshop.
Baseline in 2024 on the track: 261.3 watts.
Changes made during the 17 runs: Wattshop extensions, 25 degress angle on extensions, going from ISM to Pro saddle, 15 mm more width between elbows, BTA, saddle down 10 mm. Also tested Camelpak in the suit and bottle behind the saddle - the BTS was neutral for me and the camelpak was 4 watts - but now illegal.
Numbers after all the changes: 247.3 watts.
Savings day 1 in 2024 - 14 watts.
The numbers was then the new baseline tested at the first run in the tunnel: 280.8
Changes made during the 24 runs: Specialized TT5 helmet, HUUB Plus 22 suit, bigger BTA bottle
Numbers after all the changes: 268.1
Savings day 2 in 2024 - 12.7 watts
Almost 40 watts over the 3 tests. Windtunnel also confirmed some of the findings in 2022.
Will I go to the windtunnel again? Only if I win the lottery. The track? Yeah - I think so
